Nest Wifi Mesh Signal
Doxboi
Okay so I've been looking for solutions but have not found anything for my mesh which I have not moved goes from Great signal to weak or offline. It will switch, come back and so on. I see others have had this issue but nothing ever resolved. Google what is happening? Can anyone suggest a fix? My connected devices work fine but anything connect to the two meshes I lose due to this issue.
Jeff
Hey Doxboi,
Can you give me an idea of how you have your router and points placed? Each point works to create the mesh setup by communicating with the router itself. In order to have the best results, you want your router to be in the most centralized position possible and the points within a couple of rooms distance from the router. Can you let me know what your placement looks like?
Jeff
Jeff
Hi Doxboi,
Jeff
AbigailF
Hello Doxboi,
Abi
