Nest Wifi Port Forwarding not forwarding
Mandible
I'm trying to host a web page and a plex server from one of my computers on the network.
I have assigned my computer a static ip
I have setup port forwarding in the home application.
I can get to the applications when I put in my local ip address with port.
I cannot get to the applications when I put in the nest wifi router ip with port.
I cannot get to the applications when I put in the external ip with port.
I just keep getting error messages that the port isn't open which to me means I'm not getting forwarded.
I have only a modem no other routers, I have a nest point as well, but I have unplugged that for now.
I have tried restarting the network multiple times.
I have tried disabling the firewall, no difference.
I'm not sure what else I could try.  Is there a nest wifi dmz option that I could just send all external requests to my one computer on the network?
6 REPLIES 6
RXShorty
Hi @Mandible
Are you able to reach the plex server within your local network?
If not, port forwarding is not going to help out as this is only intended for external/internet access.
When it is not reachable from a local network client, your problem is somewhere on the server itself?
On what kind of device did you install the Plex server?
Yes I can get to it directly in my network.
AbigailF
@RXShorty, appreciate your helpful response.
@Mandible, chiming in to ensure everything is good here. Were you able to see RXShorty's other questions? Let us know if you need more help.
Abi
AbigailF
Hi Mandible,
Abi
Mandible
Yes I figured it out.
The ISP provided modem has the ability to be used as a router.  ( of which I was not using it in that way )
The wan line to my network was plugged in the incorrect port( not clearly labelled and was moved recently in my house ), which allowed internet traffic normally but created a double nat layer.  Once the wan line was plugged into the correct modem port my router port forwarding worked properly.
AbigailF
Hey Mandible,
Awesome — glad to hear that your issue is fixed. It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Abi
