12-21-2023 08:31 AM
Purchased a Nest Wifi Pro 2 pack. Setup the first unit without an issue however the second unit has been giving me nothing but problems. From the initial setup the mesh test failed and the AP began blinking yellow and would power cycle every once in a while. I factory reset the unit and set it up again with the same result. I unplugged the unit and power cycled both units for good measure. Both units came up and seemed stable however this morning the problem unit was once again blinking yellow and power cycling every once in the while. The app claims to see both units online however while in the same room as the problem unit my phone is coming up as being on 2.4Ghz and not 6Ghz like I see when standing withing range of the other unit and nothing seems to clear the blinking yellow light issue.
When I attempt to do a warranty claim on the unit the warranty checker only comes up with devices in my home that are long since out of warranty and the devices that are still covered don't show up at all. Seems a bit odd to me how that happens.
Anyone here able to offer support or assistance with this?
01-09-2024 12:03 PM
Hi GwenB,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? What device are you using to set up your network (iOS or Android)? Do you have the Internet on your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
