05-26-2023 03:54 PM
I have nest wifi router with 3 nest points and one Google puck (wired). So total of 5 (max allowed). However at least two nest points shows weak connection no matter where I place them. In the same room where router is placed or next to Google wifi puck (which shows great connection as it is wired). Gone thru restart, factory reset and moving them around but not getting intended out come.
05-27-2023 08:42 AM
I’m seeing similar results with my Nest Pro points. 1 moment they are showing “Great” the next 2 out of the 3 are showing weak and reporting slower than usual speeds.
Out of all the mesh systems I’ve used, this one appears to be the worst yet.
These issues need looking into and sooner rather than later.
