12-06-2023 03:46 PM
When I first installed my mesh wifi, I was able to add port forwarding rules with ease. Now, about a year into the mesh system, I cannot add any new rules, my device list seems to not be updating, and I show devices on the list that do not exist on my network.
I have looked at the other posts regarding this and I do not have a double-NAT system. My main router devices (Nest router) is connected directly to the ISP modem, and I have 6 or 7 satellite nest devices throughout the house, garage, and shop. It is a relatively small space, 1900 sf, standard construction home.
I need to be able to update the connected device list at will, and add or remove port forwarding as needed.
MSnyder
12-18-2023 02:56 PM
Hi mksnyder57,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions to narrow things down:
A few possibilities come to mind like incorrect port numbers and IP addresses which shouldn't be the case here since you’ve already established port forwarding rules. A power outage may have caused disruption in the connection or maybe an upstream router that is not set in bridge mode.
To start with, you can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Dan
