11-12-2022 02:40 AM
I am not able to connect to smart plugs from Deltaco because Deltaco smart home requires 3.4Ghz wifi network. I am asked to change to 2.4Ghz neteork by the Deltaco app. How can I do that with Google Nest?
Any other smart plugs that work with Google Nest?
11-12-2022 04:26 AM
You can't disable or rename 5ghz SSID.
Some say TP-Link Kasa works. More info from the past:
11-12-2022 02:17 PM
If you move far enough away from the Wi-Fi router, it should change it to 2.4 GHz which should help connect the smart plug. The closer you are to the router the better chance of getting 5 GHz which is not helping you.
11-14-2022 03:50 PM
11-17-2022 03:57 PM - edited 11-17-2022 03:57 PM
Hi Vossing,
Abi
11-18-2022 04:34 PM
Hey Vossing,
Abi
