Peloton won’t connect to mesh system
CSandman
Installed a new three-piece mesh system in the house and the peloton shows connected no Internet. I am able to connect through the hotspot on my phone so I know it is not the peloton. I have done a factory reset on the bike, forgotten all of the Wi-Fi networks turned off Wi-Fi, restarted the modem and routers unplugged every extender and still cannot get the bike connected. Any advice would be appreciated because it is currently unusable. This also happened with my Samsung TV but I figured out how to add it as a device through SmartThings, but Peloton does not appear to have an app that needs to be connected.
olavrb
Have you tried to disable WPA3 on Nest Wifi?
It might be enabled by default. Even though it's enabled WPA2 is too, legacy devices should fall back to WPA2.
Else you might want to look into a 2.4ghz only access point for difficult IoT devices.
I don't work for Google.
olavrb
Check and correct date and time on the Peloton? Ref:
CSandman
That’s the first thing I checked thank you. I went down the tech blog feeds for 2 hours trying everything before I gave up.
olavrb
