Problem Connecting to Cloud
Allen997
I just got a Google Nest WIFI and was trying to set it up. I followed the instructions and connected it to my modem, downloaded Google Home on my iPhone and tried to set it up. Everything went well in the beginning. I found the device on Home, scanned the QR code, connected my phone to its WIFI (with the default name) and was able to use the WIFI, then "problem connecting to cloud" jumped out. So I wasn't able to finish the setting or change the WIFI name & password.
I have tried to restart the app, the modem and the Nest(several times). I even tried using Pixel 2 to set it up but also failed. I saw in the community that other people are facing the same problem, so I'm wondering has the tech team found a way to fix it? By the way I'm using it in China, is that the problem? I used VPN though.
Thank you!
7 REPLIES 7
MichaelP
Hello @Allen997
Google/Nest WiFi is not supported for use in China, and is unlikely to work there. The units themselves need to be able to connect to Google's cloud services. So, having your phone on a VPN isn't enough.
Thank you for your reply! Is there anything I can try though?
Thanks!
I'm afraid I don't know of any workaround for this. Presumably a VPN of some kind could, but it would have to be outside your Google/Nest WiFi system, not inside.
Jeff
Hey, Allen997.
Unfortunately options are pretty limited for using hardware in regions where it's not supported. Some things work fairly well, but when the devices rely on cloud services, it gets a lot trickier. I can't think of a way to get things to work fully in China, but if you can find a workaround, it would probably be a big deal for lots of people in a similar situation. Your best bet is probably to find a solution that's designed for the local market and work within that ecosystem.
Thanks.
Jeff
Hi, everyone.
Thanks
Jeff
Hi, Allen997.
I just wanted to check in real fast to see if you saw MichaelP's explanation and to find out if you still needed any help on this. If you're still needing assistance, please just let me know and I'll be happy to continue helping.
Thanks.
Allen997
Yes I saw his explanation. I'm wondering is there anything that I can try so that I can use Nest Wifi in China? I know that some people are using them in China and I just don't know how.
Thank you!
