02-08-2022 05:11 PM
I have an existing nest wifi setup with two routers which work great. I want to improve coverage in my unattached garage and purchased a used nest wifi router & point. I can not get the additions added to my existing wifi network. I have done the factory reset (button method) numerous times to clear out any old settings from the previous owner. The router and point (attempting to add one at a time) seem like they are connecting but then always time out before reaching the internet or are found to be "offline" if I do a mesh test. My original two routers pass these hurdles without issue but the new ones seemingly can not.
I have even tried disconnecting my existing wifi, turning off the modem, and after the appropriate time starting up the modem again with only the newly purchased "used" units and they still will not connect to the internet. Did I buy two broken pieces of equipment or is there another way to force the settings on the "new" units to clear so they can be fully-added in the Home app?
If it makes any difference I am using the Android version of the app on my Pixel.
Thanks in advance for any and all suggestions. Michael
05-31-2022 06:20 AM
SUCCESS! I had an opportunity to work on this over the weekend and decided to start from scratch, including deleting my wi-fi network, factory resetting all of the router/points, and this time trying a different router as the main (hard-wired) router connected to my modem. I added back the other two routers (now operating as wifi points) one at a time, and finally added the true nest point in the garage,
The wi-fi network is fully up and running, the mesh test shows great connections throughout, and a dozen speed tests (both in the Home app) and separately via checks with my browser and fast.com indicate reliable wi-fi speeds throughout my home faster than my providers stated tier connection speed.
Thank you for your help and encoragement to keep at it. Very happy with the results!
MikeL
02-10-2022 09:57 AM
One more bit of information that might be helpful i do NOT have an upstream router from my nest, the main nest router is plugged directly into a Linksys CM3016 cable modem and not any kind of combo modem/router.
02-12-2022 04:29 PM
OK 1 More update, I disconnected my current Nest Wifi Routers, shut down the modem, waited, restarted the modem, waited, plugged in the recently purchased nest router, created a brand new wifi id, etc and the router connected to the internet. I was also able to add the point. So I know now that the recently purchased items are not defective.
I did factory resets on the devices again and then unplugged them.
I reattached my original nest routers, got them up again with my original wifi id so that all of my other connected devices work. Went to add the recently purchased 3rd router and point and neither one of them would connect to the network.
Anyone have any advice????
03-05-2022 09:36 AM
Hi MikeL319,
Thanks for reaching out. I'm sorry to hear that you're having an issue with setting up your additional Google Nest WiFi router and point. I'd love to know more about this and I have a few questions:
Edward
03-05-2022 12:43 PM
The setup process seems like it's working as it moves step by step through the process, (skipping some of the steps as I think back to what happened) the router is found, I attempt to add it, it appears to join the wi-fi network, it asks for several permissions for analytics, etc. and then as it's on the last step, connecting to the internet, it says "setup failed". It asks me to try again, then after going through all of the steps again it fails again. I get a message asking me to remove it from the network and reset, which I do (I have done the button reset multiple times) and the software reset.
03-31-2022 10:01 AM
Hey, MikeL319.
As an update for you, I wanted to let you know that we have a firmware update coming out now. Some people may have already received the update, but most will see it coming still. Everyone will have it before the end of April. If you receive that update and don't see an improvement with your setup issue, please let me know and we can keep looking into things.
Thanks.
04-04-2022 11:03 AM
Hey, MikeL319.
Just as some added info, the update version for both Google WiFi and Nest WiFi will be 14150.43.80. If you are seeing a different version number when you check in Google Home, you have yet to receive the updated firmware. Let me know if you have any questions about that.
Thanks.
04-06-2022 06:40 AM
Thank you for the information. I have the updated Google Home App on my phone but if I'm checking the correct spot in the router's device settings, it appears that I have not received the firmware update yet. Of the 2 routers that are currently running, the software is shown as version: 13099.118.19 on the main router (hardwired to the modem) and 13729.57.27 on the other . Will check again this weekend to see if I received the update.
04-08-2022 10:31 AM
Hi, MikeL319.
I just wanted to follow up to see if you saw my replies about the update and to see if you still had any questions here or if you managed to work things out. If you have any questions, please let me know.
Thanks.
04-08-2022 04:16 PM
I did see your reply and I'm sorry and I attempted to reply in Gmail and I must not have sent the message before shutting my chromebook off because I do not see it now. I am eagerly awaiting the firmware update to see if that helps. If I'm looking at the correct spot within the home app my current 2 nest routers (operating as a router and a point) are on "software version 13099.118.19" for the router hard wired to my modem and software version 13729.57.27 for the one operating as a point.
04-11-2022 10:12 AM
Hi, MIkeL319. Here are the firmware version numbers for the update that's coming out now. It looks like you're still waiting for updates on both the router and the point. See below for the updated numbers.
Let me know if you have any more questions. Thanks.
04-12-2022 08:49 PM
is there any way to "jump-start" the update process from my end rather than waiting for the roll out to reach me?
04-18-2022 10:06 AM
Hi, MikeL319.
There's no way to force the update, but it will be fully rolled out to everyone by the start of next week. Sometimes a power cycle can prompt the download and install, but it's not necessary to make the update occur.
Thanks.
04-27-2022 02:57 PM
Hey, MikeL319.
I just wanted to circle back on this. The update should have been installed by now so I wanted to see if you've noticed any difference for the better. Let me know what you're seeing on your end.
Thanks.
04-30-2022 05:42 AM
I'm not sure that the update has been received on my existing system, or at least not to the update versions you mention (unless I am checking the wrong spot in the settings).
The main router, hard-wired to my modem was on :
software version 13099.118.19 and is, as of this morning unchanged
the 2nd router that is operating as a point was on:
software version 13729.57.27 but has updated to 14150.43.80 so that one seems to have updated.
I hope to work on setting up the 3rd and 4th nodes (another nest router and point) tomorrow. If it doesn't work immediately I will try switching my existing nest routers (switching the router & router/point) and see if that helps either to get the update on the main router.
Thanks for continuing to check in with me from time to time.
05-03-2022 07:10 PM
While life happens and I was not able to work on this over the weekend. At this point, I did check the main router and no update ihas come thru. Will not be feasible to look at this again to first weekend in June. Will update you on the status then and attempt to add the other wifi points.
05-04-2022 10:26 AM
Sounds good, MikeL319. As you're able to check things out, just let me know what you're seeing. I'll be happy to keep this open until you're able.
Thanks.
05-09-2022 10:16 AM
Hi, everyone.
Thanks.
05-09-2022 11:23 AM
Tried to add the new point last night but failed at the same spot during the installation as before. Main router has still not updated despite manual disconnect and reboot.
If you can leave this open as I will not be able to work on this again until late May or 1st weekend in June.
05-10-2022 01:55 PM
No problem, MikeL319. We can leave this open as you're still not seeing resolution.
05-31-2022 06:20 AM
MikeL
