05-18-2023 03:35 AM
My incoming speed is nearly 500MB but Nest wifi is only around 80MB on. What can be done to fix this?
05-18-2023 05:42 AM
Where and how did you measure 80mbps? Wirelessly? By ethernet cable? Inside the Google Home app?
Some things to check.
1. Make sure modem is put in bridge mode to avoid double NAT, which can cause performance issues.
2. Make sure the ethernet cable used to connect Nest Wifi with your modem is capable of gigabit speeds, and not damaged in any way. Could be worth trying a different ethernet cable, just in case. Same goes with every other ethernet cable and other equipment (like switches) involved.
3. The placement of the Nest Wifi units has huge impact on wireless performance.
05-20-2023 02:03 PM
Hi, tried a different cable, no difference in speed, I’m measuring Wi-Fi speed on my phone right next to the router. Router is in NAT and can’t be changed due to other points in bridge mode.
Is there anything else I can try? I have had 300Mbs briefly a few months ago but never over 90Mbs these days.
Rob
05-20-2023 01:00 PM
Hello everyone,
@olavrb, your assistance here is greatly appreciated.
@Robbprice, I'm checking in to see if you were able to do the steps above. I want to make sure everything is covered on your end, so let me know if you still need help.
Lovely
05-31-2023 06:24 AM
I have exactly the same issues, 860 down, 35 up but 80-120 when measured on Iphone or laptop
05-31-2023 06:31 AM
Have you been able to sort it?
The Google Wi-Fi app says it’s 800 & 70 but fast.com says 90 & 60 😢
05-31-2023 06:33 AM
No, just tested and same. It’s totally an issue with the Access points
08-10-2023 07:04 PM
Sorry for the late revert. I just want to check if you are still having any issues. If you do, please let me know what steps you have taken so far so we can give you the right level of help. For those of you who have already contacted support but the issue remains, share your case number with me so I can check on it further.
Lovely
08-14-2023 03:49 PM
I know it has been a while, but I want to ensure that everything is covered on your end. Feel free to inform me here if you still need a helping hand.
Lovely
06-01-2023 09:57 AM
Same issue here. The new firmware update didn't fix my issue. I've been dealing with this for over a month and a half. It seems to be a common problem with no fix from customer support.
