10-30-2021 06:43 PM
Speed test started failing yesterday. Network speeds are OK and 3rd party speed tests OK. Test in Google Home always shows failed or 0 for result. I have tried system reset, 10 min power off for routers, points, modem, toggled the privacy setting for cloud as suggested in other posts. No change after any of these,
10-31-2021 12:17 AM
I'm not seeing the same. Maybe your ISP has blocked it?
11-04-2021 10:58 AM
Hi, BluDevil1986.
I just wanted to jump in real fast to see if you saw olavrb's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
11-05-2021 11:29 AM
Hi, everyone.
Thanks
