06-04-2022 11:56 PM
Using Google Home speed test I see the expected 35Mbps down/5Mbps up - close to what my broadband provider says that it’s providing. However, using the Speedtest app on my iPhone 12 I see a similar 35Mbps down but only 0.5Mbps up.
I’ve just done a full factory reset of my Google hardware, having previously done a reboot of my router.
This clearly, to me anyway, indicates that it is the Google Nest Wi-Fi that is throttling my upload speed. It’s a relatively recent problem, but is causing me issues.
I’ve seen this discussed, but can’t see any resolutions in those posts.
Anyone have any ideas,
07-13-2022 02:42 AM
Hi Jeff.
i spent some time speaking with my broadband provider and tested via another router to see if it was their problem. At the same time I rewired my connections so more traffic goes through my Powerline devices. I also turned off the 24 hour Google Nest camera feed so it now only records events, significantly reducing the upload volume.
After doing all of this, and switching back to my original router, download speeds are good at 35Mbps or more and upload has vastly increased to close to 9Mbps.
So this might be a combination of all the things I did, but it might also be that our line rating had also been upgraded to around 10Mbps, which I noticed when discussing with my provider.
So I have to say it probably wasn’t the Google devices, although they were restarted and factory reset during the process as well, but I won’t be able to categorically say what helped, but just that I’m more happy again!
Thanks for your concern and help.
Paul
06-09-2022 03:10 PM
Hey there, Tiptopp.
Sorry for the speed issues you're seeing. I know it's frustrating getting those lower than expected numbers. I know you have seen a few other threads on this, but I want to make sure you try these things out before we move onto other steps.
If you see any changes at all, for better or worse, after trying those things out, let me know. I look forward to your response.
Thanks.
06-09-2022 09:59 PM
Thanks for replying, Jeff.
In response to your message, I did various things with the following results;
My two conclusions from this are that prioritising a device, even if it’s not being used actively, kills the speed for everything else, and that the Nest devices like any other attention you give them so give a little bit more back to you!
I’m hoping that you get something more technical out of these results - happy to do more!
06-10-2022 10:03 AM
Thanks for running through all those tests, Tiptopp. I know that was a lot to test out.
I'll take that info into account as I look more into this. I'll let you know what more I can find out soon.
Thanks.
07-08-2022 09:22 AM
Hey, Tiptopp.
I know it's been a while since I touched base. I still haven't been able to find resolution on this issue, but others have reported similar results. We're still looking into things, but I didn't want you to think I had abandoned you here. By any chance have you seen any changes in your situation?
- Jeff
07-12-2022 03:06 PM
Hi again, Tiptopp.
I'm just following up again to see if you noticed my latest message and to see if you had seen any changes.
- Jeff
07-13-2022 02:42 AM
Hi Jeff.
Paul
07-13-2022 11:13 AM
Great news, and I appreciate the update! I'm sorry it was such a long road to find some answers.
Before I mark this as resolved, is there anything else you might need?
- Jeff
07-18-2022 11:04 AM
Hi, all.
As we got our resolution here, I'm going to mark this one as resolved soon. Thanks to all who helped and contributed. If anyone has any other needs, please feel free to open up a new thread.
- Jeff
