Using an outdoor wifi bridge to connect a google nest system to a secondary google nest system
jlewis2113
Is it possible to us an outdoor wifi bridge to connect a google nest system to a secondary google nest system so the network is identical. Same SSID same ip address etc.
olavrb
As long as the wireless bridge acts as a ethernet cable as far as the Nest Wifi units are concerned, that should work, yes.
  • Modem -> Primary Nest Wifi WAN port -> Primary Nest Wifi LAN port -> Wireless bridge "sender" -> Wireless Bridge "receiver" -> Secondary Nest Wifi WAN port
You could also throw some unmanaged switches in there to get more ethernet ports:
  • Modem -> Primary Nest Wifi WAN port -> Primary Nest Wifi LAN port -> Unmanaged switch any port -> Unmanaged switch any other port -> Wireless bridge "sender" -> Wireless Bridge "receiver" -> Unmanaged switch any port -> Unmanaged switch any other port -> Secondary Nest Wifi WAN port
This will appear as wired backhaul for Nest Wifi, which you can read more about here:
I don't work for Google.
MichaelP
Agree with everything @olavrb said, but would just caution that the secondary Nest WiFi Router unit will be acting as an access point, not the root of another mesh. It will effectively be a wired secondary, and those don't participate in the wireless mesh interconnect, and therefore other wireless mesh secondaries cannot be supported in other building. Otherwise, this setup does work. I haven't done it personally but I have heard from other customers who have successfully. Just take it all one step at a time, building the pieces up and testing in between each step instead of skipping straight to the final (and most complex) configuration.
AbigailF
Thanks for lending a hand, @olavrb and @MichaelP.
@jlewis2113, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
AbigailF
Hi jlewis2113,
Abi
AbigailF
Hello jlewis2113,
Abi
