Wifi 6E problems on Pixel 7 Pro
Georgebajelidze
Hi Google Pixel 7 Pro only supports Nest WiFi 6E?  I'm using a TP Link Axe75 with WIFI 6E support and the phone doesn't see 6Ghz.  Please tell me GP4BC does this model really support 6 Ghz and if it does, why can't it see the current frequency?
RXShorty
Hi @Georgebajelidze
The Pixel 7 Pro supports wifi 6.
It still connects to 5 GHz frequency but if you scroll down in you connectivity details you will see the type: Wifi 6.
Thanks for the reply, but I think the Type WIFI is 6, but it shows the frequency 5Ghz instead of 6Ghz, also TP Link doesn't show the device connected to 6Ghz in the list of clients.
Hi @Georgebajelidze
It seems to be region specific. Please check THIS link.
I checked and it supports 6 GHz in the European region, I'm currently in Georgia and GP4BC is the global version 😔.  Thanks again for your attention
@RXShorty, I appreciate you helping out here.
@Georgebajelidze, thanks for posting. For your concerns about connecting your Google Pixel 7 Pro to Wi-Fi 6, you can post a message over at https://goo.gle/3PpiGd2 — they're best equipped to assist you.
Let us know if you have additional questions or concerns; otherwise, I'll close the thread after 24 hours.
Lovely
