Wifi keeps dropping and can't connect using 6E
kruegerb
I had a Google Wifi  and Nest Wifi mesh network.  Purchased two Google Nest Wifi Pro and connected per the below diagram.
-> Ethernet Cable
. .> Wireless
Modem -> Google Nest Wifi Pro (Network #1) -> TL-SG105 switch (S)
(S) -> Google Nest Wifi Pro #2 (Network #1)
(S) -> Nest Wifi #1 (Network #2) . .>  Google Wifi #2 (Network #2)
Laptop with ax Network adapter connected to Network #1 is unable to see any 6 Ghz network.
Google Pixel 6 Pro also unable to see any 6 Ghz  network.
Google Pixel 6 Pro connected to Network #2.
Both Network #1 and Network #2 drop internet intermittently.
Recommendations to fix network for maximizing.
olavrb
Enable WPA3 on network 1 if not already enabled.
Remove network 2, that is just asking for problems.
I don't work for Google.
LovelyM
Hello everyone,
@olavrb, I appreciate you providing helpful suggestions here.
@kruegerb, thanks for reaching out. I want to check if you have tried the steps suggested above. Please let me know if you are still having trouble from here, as I would be happy to take a closer look and assist you further.
Lovely
LovelyM
Hi kruegerb,
I want to check if you still need help. Please tell me if you still have questions or concerns. I want to ensure you're all sorted out.
Lovely
