Will my wifi point remember settings after turning off and on?
FreeAlpa
Hi! Can a wifi point- not a router or google nest, I mean a wifi extension- remember the settings of wifi connection even if I unplug and replug it?
My landlord needs to set the wifi extension up again, but I want to suggest that he configure it in his own home and then I can just receive it and plug it in here.
I just prefer not having visitors at the moment.
olavrb
"Can a wifi point- not a router or google nest, I mean a wifi extension- remember the settings of wifi connection even if I unplug and replug it?"
Yes.
"Are there any products where that’s not possible?"
Not that I know of, that would be a poor design. Power interruption should not delete settings of a network device.
I don't work for Google.
7 REPLIES 7
olavrb
Yes it will.
FreeAlpa
olavrb
Yes.
FreeAlpa
For the sake of future reference, obviously the unplugging of the Ethernet cable does nada as well, since the device needs power to perform any action.
As long as it’s within range of the main point (router, google nest primary point, etc) when plugging it in, in all likelihood it’ll work fine.
Thanks for the help:D
Juni
@olavrb, thanks for the help.
@FreeAlpa, sorry for the late revert. I hope you've got the answer you're looking for. If you're still in need of any assistance, feel free to let us know.
Juni
Juni
Buzzing in — do you still need our help? Don't hesitate to reach back if you do.
Juni
Jhonleanmel
Mel
