01-17-2024 10:21 PM
I build and test lock-app with matter over wifi.
suddenly, my matter device does not work.
I was commissioning Google Nest Hub / Pixel 5a and Apple Home Pod mini / iPhone.
my lock-app cluster could be controlled and subscribe status from above each platform.
At last week, I controlled my lock-app cluster from Apple home network,
however, my lock-app cluster's status does not change on Pixel 5a Google Home App.
Can I check, remove and control matter device from developer console?
If yes, would you please disclose tutorial / How to?
01-21-2024 08:43 PM
Hello @mt0msk ,
Thanks a lot for reaching out to us with your issue. You cannot check, remove and control matter devices from the developer console. You can only check and remove devices using the Google Home App.
01-21-2024 08:43 PM
Hello @mt0msk ,
01-21-2024 09:56 PM
Thank you for your reply.
I understand it.
I will post problem of matter smart lock with Google Home App.
