07-18-2022 08:12 PM
Is there a way to get the web bluetooth API to work with Nest Hub? Please let me know if there are any documents that I should read. I am developing a web application that works with devices such as ESP32, and the purpose is to run it on the nest hub.
07-20-2022 02:48 PM
You can go through the Device Access API to see which APIs are available to control Nest Hubs, and the features they provide. More information in this regard can be found under the Supported Devices section. Currently our devices can only be controlled through our Web API (Device Access), and no other remote communication APIs are available.
07-20-2022 02:48 PM
07-20-2022 10:24 PM
Thank you for answering.
I read the introduced doc and realized that it was difficult to do the way I was thinking.
I'll Think about other ways.
thx, sipriyadarshi !
09-24-2022 06:27 PM
Zip
