01-05-2025 07:46 AM
I am unable to create a project using the Device Access Console. My account is active. I have agreed to the terms and paid the $5. There is zero additional information on the cause of the error/issue.
I can see that others have had the same issue. But no root cause/fix.
Your assistance would be appreciated.
01-09-2025 08:23 AM
Thanks for reaching out. The recent issue affecting the device access account creation(pub/sub enabled) has been resolved. We apologize for any inconvenience this may have caused and appreciate your patience during the resolution process.
01-06-2025 05:10 PM
Same issue here, don't know what I'm doing wrong.
01-07-2025 07:34 AM
To add. I created an entirely new, unrelated account and had the same issue. Has anyone successfully created a project recently?
01-07-2025 07:53 AM
Found a workaround. On step 3 disable Pub/Sub. This will let you create the project. I hope it works for you.
01-07-2025 10:17 AM - edited 01-07-2025 10:34 AM
Yes able to create the project now with workaround, but not able to enable Pub/Sub once project is created.
Found an issue tracker - https://issuetracker.google.com/issues/348675996?pli=1
01-07-2025 01:42 PM
Please have a look at this Google Nest integration - what am I doing wrong? : r/homeassistant. creating a pub/sub topic and subscription manually fixed it for me.
01-07-2025 07:08 PM
I tried to follow this but I'm either missing something or I screwed something up... after creating a topic and a subscription in my project, when I go to configure the HA integration and enter the cloud project ID and device access project id, it kicks me to a page that reads:
Please contact [project-name] if the issue persists
this is honestly enough to make me want to never buy a google product ever again...
01-07-2025 07:04 PM
--batch_H_Wu5ypVDOZHgipfbnzKsozsCJ6o7-Hn
Content-Type: application/http
Content-ID: <#>
HTTP/1.1 500 Internal Server Error
Vary: Origin
Vary: X-Origin
Vary: Referer
Content-Type: application/json; charset=UTF-8
"error": {
"code": 500,
"message": "Internal error encountered.",
"status": "INTERNAL"
--batch_H_Wu5ypVDOZHgipfbnzKsozsCJ6o7-Hn--
This is the error being returned in the Device Access Console when trying to enable pubsub.
01-08-2025 09:42 AM
You don't have to enable pub/sub in device access console. creating the pub/sub topic and subscription yourself is sufficient. In HA I did not add the device it found but I went the "add integrations" route. after about 30 mins when I created the topic and subscription it started to work. I tried many many times.
01-09-2025 08:23 AM
