09-19-2024 04:00 PM
I recently changed my router and modem and went to reconnect my doorbell. I factory reset the item and deleted it in my home app. But I cannot now get it to connect, it just sits on the screen and says it must be same Wi-Fi as the phone. The problem is it won't look for the new wifi. The blue light is pulsing to connect. I'm at my wits end messing with this for days. I uninstalled and reinstalled the home app too.
09-27-2024 10:21 AM
Hello @Solidsnake2525 ,
We are really sorry to see you facing issue reconnecting your doorbell to your new setup. I would recommend going through the following document which discusses about the steps for restarting or resetting your nest camera or doorbell device. The above documentation provides a comprehensive step by step guidance for carrying out the restart/resetting operation with different nest camera or doorbell device types.
09-27-2024 10:21 AM
11-18-2024 08:23 AM
I have the same problem and nothing of the above works.
07-30-2025 12:43 PM
I'm having the same problem, can I ask if you got this resolved please?
08-10-2025 09:32 AM
Same problem here. NOTHING works. All other devices connected. Google makes this process grueling.
08-10-2025 10:00 AM
Hi all, my broadband subscription was due for renewal and I switched to eero routers, connected straight away. So not sure what the issue was.
