02-21-2024 04:41 PM
This is what the Google Nest Employee told me on the phone today (some of these might be true?):
I don't understand how any of these can actually be true. Did Google really make it so that you should not buy more than one of their products? Their network equipment is not smart enough to operate over a simple home network that uses both 2.4 GHz and 5 GHz? You are out luck if you have to replace an access point or router? As for the last point, I have been able to get many of my offline devices back by power cycling them and rebooting access points and routers.
Can someone please explain the technical reasons behind the limitation that the Google employee told me?
02-22-2024 01:34 PM - edited 02-22-2024 01:37 PM
Hi Rob,
Thanks for reaching out. We're happy to help understand more about Matter.
1. Multiple Matter controllers are expected to coexist in a single IP network. However for the purpose of troubleshooting, it can sometimes be helpful to isolate a single controller as a diagnostic step.
2. Google's controllers operate on both, but some end devices only operate on the 2.4 band. For most situations this should not be an issue, but is something to be aware of.
3. Inaccurate; Matter requires IP infrastructure to function.
4. Only the same IP/Thread networks should be required for the new hub. The matter end device itself possesses credentials for its operational network. When setting up a new AP: Thread should manage itself, and for WiFi you can re-use the SSID and password and move everything over.
5. Inaccurate, but recommissioning is one common method to recover from device offline issues
Hi Rob,
02-23-2024 10:13 AM
Thank you so much for clearing that up!
