02-19-2024 10:30 PM
I created matter virtual device with on/off clusters and it's working well but when I try with the physical device getting
"Search for Devices"
Logcat:
runDevicesPeriodicPing deviceId [1]
getDeviceStateOnOffCluster())
FindOrEstablishSession: No existing OperationalSessionSetup instance found
OperationalSessionSetup State change 1 --> 2
resolve: Starting service resolution for 'F440DE2737487CDF-0000000000000001' type '_matter._tcp'
Checking node lookup status after 202 ms
resolve: Timing out
ViewPostIme pointer 0
mReversing is false. Don't call initChildren.
onDisplayChanged oldDisplayState=2 newDisplayState=2
ViewPostIme pointer 1
addDeviceButton.setOnClickListener
CommissionDevice: starting
commissionDeviceStatus.observe: status [TaskStatus$InProgress@f100b3a]
ShareDevice: Success getting the IntentSender: result
commissionDeviceIntentSender.observe is called with [creatorPackage [com.google.android.gms]]
CommissionDevice: Launch GPS activity to commission device
Recording user engagement, ms: 85765
commissionDeviceIntentSender.observe is called with [null]
handleWindowFocusChanged: 0 0 call from
onPreWindowFocus: skipped, hasWindowFocusfalse mHasImeFocus=true
I onPostWindowFocus: skipped, hasWindowFocusfalse mHasImeFocus=true
Connecting to remote service
Connection attempt already in progress
Activity paused,
Connected to remote service
Processing queued up service tasks: 2
onCreate()
intent [Intent { commissioning.AppCommissioningService }]
Local module descriptor class for com.google.android.gms.googlecertificates not found.
Considering local module com.google.android.gms.googlecertificates:0 and remote module com.google.android.gms.googlecertificates:7
Selected remote version of com.google.android.gms.googlecertificates, version >= 7
Dynamite loader version >= 2, using loadModule2NoCrashUtils
ClassLoaderContext classpath size mismatch. expected=12, found=17
Input channel destroyed: 'ClientS', fd=123
handleAppVisibility mAppVisible = true visible = false
Relayout returned: old=(0,0,1080,2640) new=(0,0,1080,2640) relayoutAsync=false req=(1080,2640)8 dur=8 res=0x402 s={false 0x0} ch=true seqId=0
stopped(true) old = false
WindowStopped on set to true
Relayout returned: old=(0,0,1080,2640) new=(0,0,1080,2640) relayoutAsync=false req=(1080,2640)8 dur=7 res=0x402 s={false 0x0} ch=false seqId=0
2024-02-20 11:20:55.247 1872-3273 WindowManager system_server E win=Window{b21c0a u0 } destroySurfaces: appStopped=true cleanupOnResume=false win.mWindowRemovalAllowed=false win.mRemoveOnExit=false win.mViewVisibility=8 caller=com.android.server.wm.ActivityRecord.destroySurfaces:6900 com.android.server.wm.ActivityRecord.destroySurfaces:6881 com.android.server.wm.ActivityRecord.activityStopped:7576 com.android.server.wm.ActivityClientController.activityStopped:310 android.app.IActivityClientController$Stub.onTransact:702 com.android.server.wm.ActivityClientController.onTransact:175 android.os.Binder.execTransactInternal:1380
Application going to the background
Application backgrounded at: timestamp_millis: 1708408254693
Checking node lookup status after 15015 ms
OperationalSessionSetup[1:0000000000000001]: operational discovery failed: 32
Unable to get connected device with nodeId 1.
connectedDevicePointer.
runDevicesPeriodicUpdate: cannot get device on/off state -> OFFLINE
runDevicesPeriodicPing deviceId [1] [false] [false]
devicesUiModelFlow changed ***
processDevices() deviceId: [1]}
deviceId setting its own value for state
Inactivity, disconnecting from the service
and
"Can't find device"
and some instructions page visible witch is already tried by many times
02-22-2024 11:27 AM
Hello @Rgv27 ,
The log you shared tells us that commissioning failed at operational discovery, i.e. we did not get a response for mDNS queries after the device joined WiFi. We might be needing additional details regarding the physical device build (SDK commit, SOC, example used , etc). Also, could you inspect wireshark captured during commissioning.Without these details it is difficult for us to do a proper investigation of your issue.
02-22-2024 10:59 PM
Hello @sipriyadarshi , Can you please tell me about the hub, is that require for connectivity with the single matter physical device to my app ?
02-22-2024 11:19 PM
@sipriyadarshi , and also the certification of app is require on google console for commissioning of devices ?
Thanks
02-26-2024 03:48 AM
I got some different message
Logcat
commissionDeviceStatus.observe: status []
ShareDevice: Success getting the IntentSender: result [IntentSender{}]
Activity paused, time: 1210054748
Compat change id reported: 150939131; UID 11471; state: ENABLED
onCreate()
intent [Intent { .commissioning.AppCommissioningService }]
Input channel destroyed: 'ClientS', fd=135
Application backgrounded at: timestamp_millis: 1708941845549
Late-enabling -Xcheck:jni
Using CollectorTypeCC GC.
setConscryptValidator
setConscryptValidator - put
Compat change id reported: 171979766; UID 11471; state: ENABLED
Compat change id reported: 242716250; UID 11471; state: ENABLED
Currently set values for:
angle_gl_driver_selection_pkgs=[]
angle_gl_driver_selection_values=[]
com.slappi is not listed in per-application setting
App is not on the allowlist for updatable production driver.
Compat change id reported: 183155436; UID 11471; state: ENABLED
Device unlocked: initializing all Firebase APIs for app [DEFAULT]
FirebaseApp initialization successful
QUALCOMM build : 12ae96cb63, I409bbc12eb
Build Date : 09/13/23
OpenGL ES Shader Compiler Version: EV031.35.01.10
Local Branch :
Remote Branch :
Remote Branch :
Reconstruct Branch :
Build Config : S P 10.0.7 AArch64
Driver Path : /vendor/lib64/egl/libGLESv2_adreno.so
PFP: 0x016dc112, ME: 0x00000000
Selected remote version of com.google.android.gms.measurement.dynamite, version >= 102
Checking for metadata for AppLocalesMetadataHolderService : Service not found
ClassLoader referenced unknown path:
onActivityCreated
setWindowBackground: isPopOver=false color=fffef7ff d=android.graphics.drawable.ColorDrawable@8e650d5
Accessing hidden method Landroid/view/View;->computeFitSystemWindows(Landroid/graphics/Rect;Landroid/graphics/Rect;)Z (unsupported, reflection, allowed)
Accessing hidden method Landroid/view/ViewGroup;->makeOptionalFitsSystemWindows()V (unsupported, reflection, allowed)
Compat change id reported: 210923482; UID 11471; state: ENABLED
App measurement collection enabled
App measurement enabled for app package, google app id:, 1:775073109900:android:88525231b865fc4da928a9
App measurement initialized, version: 85000
To enable faster debug mode event logging run:
Compat change id reported: 237531167; UID 11471; state: DISABLED
Access denied finding property "persist.dm.passive.display_brightness"
Access denied finding property "persist.dm.passive.ambient_brightness"
[NativeCFMS] BpCustomFrequencyManager::BpCustomFrequencyManager()
Resetting session stitching token to not null
synced displayState. AttachInfo displayState=2
setView = com.android.internal.policy.DecorView@91a1e58 TM=true
Starting IDS observe window
App has not finished training
Closing IDS observe window
Activity resumed, time: 1210117805
Tag Manager is not found and thus will not be used
mThreadedRenderer.initialize() mSurface={isValid=true 0xb400007379265cf0} hwInitialized=true
Setup new sync=wmsSync-ViewRootImpl@3bbcf7d[]#0
Creating new active sync group ViewRootImpl@3bbcf7d[SplashActivity]#1
registerCallbacksForSync syncBuffer=false
Received frameDrawingCallback syncResult=0 frameNum=1.
mWNT: t=0xb4000071f92508b0 mBlastBufferQueue=0xb4000071d924f950 fn= 1 caller= android.view.ViewRootImpl$8.onFrameDraw:13674 android.view.ThreadedRenderer$1.onFrameDraw:788 <bottom of call stack>
Setting up sync and frameCommitCallback
onFrameAvailable the first frame is available
Received frameCommittedCallback lastAttemptedDrawFrameNum=1 didProduceBuffer=true
CFMS:: SetUp Pid : 14166 Tid : 14205
reportDrawFinished
registerCallbackForPendingTransactions
applyRequestedVisibilityToControl: visible=true, type=statusBars, host=
applyRequestedVisibilityToControl: visible=true, type=navigationBars, host=
Processing queued up service tasks: 5
handleWindowFocusChanged: 1 0 call from android.view.ViewRootImpl.-$$Nest$mhandleWindowFocusChanged:0
mThreadedRenderer.initializeIfNeeded()#2 mSurface={isValid=true 0xb400007379265cf0}
startInputInner - Id : 0
startInputInner - IInputMethodManagerGlobalInvoker.startInputOrWindowGainedFocus
applyRequestedVisibilityToControl: visible=false, type=ime, host=
Recording user engagement, ms: 2003
onActivityCreated
Activity paused, time: 1210119808
onCreate bundle is: null
Compat change id reported: 247079863; UID 11471; state: ENABLED
commissionDeviceStatus.observe: status [com.TaskStatus$NotStarted@71c33c5]
onResume(): intent [Intent { cmp= }]
Invocation: Main
Starting periodic ping on device with interval [2] seconds
Activity resumed, time: 1210119969
startDevicesPeriodicPing every 10 seconds
setView = com.android.internal.policy.DecorView@36b5a6c TM=true
updateUi [DevicesUiModel(devices=[], showCodelabInfo=true, showOfflineDevices=true)]
Relayout returned: old=(0,0,1080,2640) new=(0,0,1080,2640) relayoutAsync=false req=(1080,2640)0 dur=8 res=0x403 s={true 0xb400007379278f80} ch=true seqId=0
performConfigurationChange setNightDimText nightDimLevel=0
mThreadedRenderer.initialize() mSurface={isValid=true 0xb400007379278f80} hwInitialized=true
Setup new sync=wmsSync-ViewRootImpl@e8081c3[BaseActivity]#2
Creating new active sync group ViewRootImpl@e8081c3[BaseActivity]#3
mWNT: t=0xb4000071f9258730 mBlastBufferQueue=0xb4000071d9246990 fn= 1 caller= android.view.ViewRootImpl$8.onFrameDraw:13674 android.view.ThreadedRenderer$1.onFrameDraw:788 <bottom of call stack>
[ViewRootImpl@e8081c3[BaseActivity]#1](f:0,a:0,s:0) onFrameAvailable the first frame is available
reportDrawFinished
handleWindowFocusChanged: 0 0 call from android.view.ViewRootImpl.-$$Nest$mhandleWindowFocusChanged:0
mWNT: t=0xb4000071f925b330 mBlastBufferQueue=0xb4000071d9246990 fn= 2 caller= android.view.ViewRootImpl$6.onFrameDraw:5582 android.view.ViewRootImpl$2.onFrameDraw:2131 android.view.ThreadedRenderer$1.onFrameDraw:788
mThreadedRenderer.initializeIfNeeded()#2 mSurface={isValid=true 0xb400007379278f80}
applyRequestedVisibilityToControl: visible=false, type=ime, host=com.slappi/com.slappi.base.BaseActivity
dispatchDetachedFromWindow
Input channel destroyed: '325b4fb', fd=110
Cleared Reference was only reachable from finalizer (only reported once)
Input channel destroyed: 'ClientS', fd=141
commissionDeviceStatus.observe: status [InProgress@3ac5515]
ShareDevice: Success getting the IntentSender: result [IntentSender]
Recording user engagement, ms: 35345
onCreate()
intent [Intent { pkg=.commissioning.AppCommissioningService }]
Activity paused, time: 1210155315
Input channel destroyed: 'ClientS', fd=124
Cann’t connect to wifi("name") network
Check that your device can work with this network type and try again
then, how can I check my device work with which network type?
02-27-2024 10:41 PM
Hello @sipriyadarshi , any update on this?
02-28-2024 02:16 AM
When I tap the pluse + button on sample app using matter sdk, scanner opened
Scanning done with code using Tapo Light L535E
Searching for the device
getting this page after searching
Hello @sipriyadarshi , please find details via the screens flow
Whats the issue in that?
02-29-2024 11:06 PM
Hi @sipriyadarshi , can we connect via call or any other resources that can I find fast response?
I tested with 2.4GHz network but still not getting success
and also I shared some code snippet when I click on add device click on add device button
NOTE -
I am using all the functions, classes and requests from the sample Matter app, I have not made any changes in my app.
If I need to change something for physical device (Tapo Light L535E) in my app then please guide me on that changes.
this is my service class -
@AndroidEntryPoint
class AppCommissioningService : Service(), CommissioningService.Callback {
@Inject internal lateinit var devicesRepository: DevicesRepository
@Inject internal lateinit var devicesStateRepository: DevicesStateRepository
@Inject internal lateinit var chipClient: ChipClient
private val serviceJob = Job()
private val serviceScope = CoroutineScope(Dispatchers.Main + serviceJob)
private lateinit var commissioningServiceDelegate: CommissioningService
override fun onCreate() {
super.onCreate()
// May be invoked without MainActivity being called to initialize APP_NAME.
// So do it here as well.
APP_NAME = getString(R.string.app_name)
Log.d("", "onCreate()")
commissioningServiceDelegate = CommissioningService.Builder(this).setCallback(this).build()
override fun onBind(intent: Intent?): IBinder? {
Log.d("onBind():", " intent [${intent}]")
return commissioningServiceDelegate.asBinder()
override fun onStartCommand(intent: Intent?, flags: Int, startId: Int): Int {
Log.d("", "onStartCommand(): intent [${intent}] flags [${flags}] startId [${startId}]")
return super.onStartCommand(intent, flags, startId)
override fun onDestroy() {
super.onDestroy()
Log.d("", "onDestroy()")
serviceJob.cancel()
override fun onCommissioningRequested(metadata: CommissioningRequestMetadata) {
Log.d("Request---->",
"*** onCommissioningRequested ***:\n" +
"\tdeviceDescriptor: " +
"deviceType [${metadata.deviceDescriptor.deviceType}] " +
"vendorId [${metadata.deviceDescriptor.vendorId}] " +
"productId [${metadata.deviceDescriptor.productId}]\n" +
"\tnetworkLocation: " +
"IP address toString() [${metadata.networkLocation.ipAddress}] " +
"IP address hostAddress [${metadata.networkLocation.ipAddress.hostAddress}] " +
"port [${metadata.networkLocation.port}]\n" +
"\tpassCode [${metadata.passcode}]")
// CODELAB: onCommissioningRequested()
serviceScope.launch {
val deviceId = devicesRepository.incrementAndReturnLastDeviceId()
Log.d("",
"Commissioning: App fabric -> ChipClient.establishPaseConnection(): deviceId [${deviceId}]")
chipClient.awaitEstablishPaseConnection(
deviceId,
metadata.networkLocation.ipAddress.hostAddress!!,
metadata.networkLocation.port,
metadata.deviceDescriptor.vendorId,
metadata.deviceDescriptor.productId,
metadata.deviceDescriptor.deviceType,
metadata.passcode)
Log.d("", "Commissioning: App fabric -> ChipClient.commissionDevice(): deviceId [${deviceId}]")
chipClient.awaitCommissionDevice(deviceId, null)
Log.d("", "Commissioning: Calling commissioningServiceDelegate.sendCommissioningComplete()")
CommissioningCompleteMetadata.builder().setToken(deviceId.toString()).build())
.addOnSuccessListener {
Log.d("",
"Commissioning: OnSuccess for commissioningServiceDelegate.sendCommissioningComplete()")
.addOnFailureListener { ex ->
Log.e("", "Commissioning: Failed to send commissioning complete.", ex)
// CODELAB SECTION END
02-29-2024 11:35 PM
This is latest Logs -
W Frame time is 0.089496 ms in the future! Check that graphics HAL is generating vsync timestamps using the correct timebase.
Recording user engagement, ms: 13103
Activity paused, time: 3750429
onCreate()
intent [Intent commissioning.AppCommissioningService ]
Application backgrounded at: timestamp_millis: 1709277938430
03-04-2024 09:47 PM
@sipriyadarshi , please update on this ?
and can you have any other resources that can I find quick response?
02-22-2024 11:27 AM
Hello @Rgv27 ,
02-23-2024 06:51 AM
Hi @sipriyadarshi , I am using Matter SDK with the Matter sample app and ChipTool
02-22-2024 10:59 PM
02-23-2024 10:44 AM
Hub is not required for commissioning except for thread devices which require some thread infrastructure. However, if you want to control the device from GHA you need a Google Hub.
02-22-2024 11:19 PM
Thanks
02-23-2024 10:46 AM
You don't need to go through any certification process for the sample app.
02-25-2024 11:32 PM
Thanks for reply @sipriyadarshi but
I didn’t find any log except I had mentioned above
So, Can you please describe some more details that are required for commissioning that how can I get a physical device ready for commissioning ?
I have a Tapo light as a physical device.
02-26-2024 03:48 AM
Logcat
onCreate()
Local Branch :
Remote Branch :
Remote Branch :
onActivityCreated
reportDrawFinished
onActivityCreated
Invocation: Main
reportDrawFinished
onCreate()
02-27-2024 10:41 PM
02-28-2024 02:16 AM
02-29-2024 02:19 PM
Hello @Rgv27 ,
Tapo only supports 2.4 GHz. Based on your screenshot "Can't connect to 5exceptions_Mobile_Team5G", looks like you have a split network. Try testing everything using a 2.4GHz network only.
02-29-2024 11:06 PM
NOTE -
@AndroidEntryPoint
super.onCreate()
super.onDestroy()
serviceJob.cancel()
Log.d("",
deviceId,
metadata.passcode)
Log.d("",
02-29-2024 11:35 PM
onCreate()
03-04-2024 09:47 PM
