Philips Hue Lights Shut off on their own
mazblufan
I am using Google Home to control Hue Lighting, Hue motion sensors and Feit outdoor outlets.  The motion sensors work fine in turning on outdoor lighting. The Feit outdoor outlet works fine in turning on lights at sunset and turning them off on time.  The Hue lights I have indoors work fine with the automation, but the external lights turn on when the automation triggers, but then they turn off on their own.  These lights also dim on their own as well.  When I notice they are off, I will turn them back on and brighten them, but they will still turn off.  Any thoughts on how to fix this?
sipriyadarshi
Solutions Expert
Solutions Expert
Hello @mazblufan ,
Thank you for reaching out to us with your issue. From what you are describing above, it appears that you have multiple light devices (indoor and outdoor). The reason why some of your lights are abruptly turn off and dim on their own could be because of these device being part of multiple automation. What you can do is to verify at your end that the devices are mapped properly to their respective automation and no same device is part of more than one automation. This will help in proper automation simulation with your indoor and outdoor devices.
sipriyadarshi
Solutions Expert
Solutions Expert
Hello @mazblufan ,
