06-07-2023 02:52 AM
Hello my developer friends, I am new to the developer section and I want to establish a connection between Node-RED and my Google Home. I have no idea how to go about it, and I want to communicate directly with Google without using services like Nora or Hardill. I am open to any possible ideas. I need to mention that I am using an automation system, so it's a local installation running in a container (Docker), and I am connected to the internet. Today, the question I have is: can I use a webhook and an HTTP In node in Node-RED to handle requests from Google Home, such as turning on the lights or opening the blinds? Thank you, my friends! See you soon!
06-19-2023 09:32 AM
06-19-2023 09:32 AM
06-28-2023 02:03 AM
Thanks for your reply. I'll give it a try and get back to you as soon as possible. Thanks in any case. LT
12-11-2023 07:52 AM
Did you get anywhere with your project?
I would like to do something similar. My project is to take the input from my Nest Doorbell and get NodeRed to generate an MQTT message and I will use that to drive an 8266 to drive a buzzer.
I have been looking at SmartNORA who have a Doorbell node, but it doesn't have an output!
And Hardill who doesn't have a doorbell node.
I am still examining both possibilities ....
Regards
Bruce
