09-22-2025 12:32 PM
I am writing to introduce a proposal for a new, open-source safety standard designed for the modern smart home.
The proposal, titled the Home Emergency Light Protocol (HELP), addresses a critical gap in residential safety: the limitations of audible-only alarms and the lack of contextual information during an emergency. HELP leverages the widespread adoption of connected RGB lighting to create a universal visual language, signaling specific events like fire, intrusion, or medical emergencies through distinct, pre-defined light patterns.
This protocol is designed from the ground up to be a royalty-free, open standard that can be implemented via a simple software update, enhancing the value of the existing smart home ecosystem and significantly improving accessibility for the deaf and hard of hearing.
I believe this initiative aligns perfectly with the CSA's mission to create a more intuitive and secure connected world. All documentation, including the strategic proposal, technical specifications, and a detailed wiki, has been published for public review on GitHub.
You can view the complete proposal here: https://github.com/brianlenehan/The-Home-Emergency-Light-Protocol-HELP-Standard/wiki
I would be grateful for the opportunity to have your teams review this proposal and would welcome any discussion on how it might complement the CSA's work, perhaps within a working group or as a future adopted standard.
Thank you for your time and consideration.
Respectfully,
Brian Lenehan Initiator, The HELP Standard Project
09-22-2025 01:56 PM
Thanks for the HELP Protocol proposal. Using RGB lights for emergency signals is a creative accessibility solution.
Key questions we'd need to evaluate:
We'll review the GitHub documentation and route this to our product and accessibility teams for assessment.
Appreciate you considering inclusive design for home safety.
09-22-2025 12:34 PM
The HELP standard is designed to be simple and intuitive. Each signal uses a unique combination of color and pattern to communicate a specific emergency clearly.
09-22-2025 01:56 PM
