Sonoff Door Sensor SNZB-04P cannot be used as starter or condition
Reverence
Hi. It seems like the Sonoff Door Sensor SNZB-04P cannot be used as starter or condition in an automation and it says support coming soon.
Is there any way to see when this functionality will be enabled?
arm_dpe
Solutions Expert
Solutions Expert
Thanks so much for reaching out. It’s a bit of a letdown that the Google Home app doesn't fully support the Sonoff SNZB-04P door sensor yet, especially since Google’s backend APIs have already been updated to recognize them.
Moving forward, a helpful tip is to treat the Supported Devices page as your "pre-purchase" checklist. It’s the most reliable resource for checking which devices are compatible with Google actions, starters, and conditions, and it will be the first place to officially announce when these sensors are fully ready for use.
2 REPLIES 2
arm_dpe
Solutions Expert
Solutions Expert
This list doesn't seem adequate; it doesn't even mention the sensor I'm using even though it seems to have partial integration with google home because the sensor state can be read and heard via voice.
