Adding mesh point after facyor reset
Autobadges
So I have issues with one mesh point being weak. I gave it a factory reset but now I can't re-add to my mesh. I had 3 points and now it's only 2. I see it as a wifi point but when I try to connect it asks for a password and it's not my wifi network password bc I already tried it.
How do I re-add my wifi point? Again,  no it doesn't show up in Home App
9 REPLIES 9
Jhonleanmel
Hi Autobadges,
Thanks for posting and sorry for the delay ― let's get this sorted.
A few questions: what device do you have? Check this link to know more: Google Nest Wifi and Google Wifi products. Also, what is the color of the LED light on your point?
Give these steps a try:
  1. Manually factory reset the device using the reset button. Here's how: Factory reset Google Nest Wifi or Google Wifi devices
  2. Add the point to your Home app.
  3. Use another phone or tablet to setup.
Let us know how it goes.
Mel
Autobadges
I have the google mesh. I'm adding a point. Point has been deleted factory reset and try to add to home app. It goes thru it all, scans it, finds it but upon thr adding to ur wifi home...says please connect to internet.  I honestly think it's a faulty point now...are these covered with some lifetime warranty?
Jhonleanmel
Hi Autobadges,
Thanks for getting back to us. Do you mean Google Wifi or Google Nest Wifi? Does the point have an Ethernet port on the bottom? If so, try to connect the point to the main point using an Ethernet cable during the setup process.
Mel
It's the Google mesh wifi. No port as this is a point, not the main router
Jhonleanmel
Hi Autobadges,
Thanks for the update. We need to factory reset the point using the reset button.
Press and hold the reset button on the bottom of the child point. Once it made the dialogue about resetting, wait for the next sound (bell sound) then let go of the reset button. Once the reset is complete after about 5 minutes, the point will make a sound saying, "To get started, download the Google Home app..".
After the reset, try to add it again on your Home app.
Mel
Autobadges
I have already tried to factory reset 5 times.  Same outcome. This was supposed to be escalated to higher level troubleshooting
Jhonleanmel
Hi Autobadges,
I'm sorry to hear that you're still having an issue with your Google Nest Wifi. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Mel
Autobadges
All filled out
Jhonleanmel
Hi Autobadges,
We got your form — thanks for filling it out. Keep your lines open as our team will reach out to you via email anytime soon.
Also, please continue the conversation there as this thread will be locked after 24 hours.
Mel
