Can we use mini nest without wifi? I don't have wifi connection.
hiteshy93
I want to connect my mini nest 2nd generation with Bluetooth to my phone. But I am unable to do that. Also I don't have a wifi connection at home. Is wifi mandatory to make connection with phone and speakers through Bluetooth?
6 REPLIES 6
Cathal_S
Gold Product Expert
Gold Product Expert
Yes an internet connected WiFi signal is required for using a Google Nest Mini.
https://support.google.com/googlenest/answer/7381505
Cathal
Cathal
Just an fyi. That linked article makes no mention of a connected WiFi signal being required to use the Nest Mini in Bluetooth mode.
SamInPgh
Actually, you can use it as a Bluetooth speaker without an internet connection if you first set it up WITH an available internet connection and pair it via Bluetooth with your phone using Google Home while it is still connected to Wifi. This initial setup can be done on any private WiFi network, such as at a friend's house, etc. After this initial setup and pairing is done, it should show up as an available Bluetooth speaker on your phone no matter where you are (as long as the Mini is within range, of course).
hiteshy93
I had setup it using wifi but now I can see the Bluetooth speaker in my phone.. but when I click on that. It keeps showing me "pairing" only.  When you say ok Google it revert back " no wifi connection found".
As I mentioned in my previous reply, you need to pair it with your phone while you are still connected to the Wifi network. It must be successfuly paired once in order to use it without the Wifi network later.
Princesss
Since this thread hasn't had activity in a while, we're going to close it to keep content fresh. To know more about connecting Google Home/Nest speakers to your network, you can click this link for your reference.
If you have additional questions, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Princess
