10-16-2025 08:26 AM
My Nest Hub Max is offline, but I can't remove it from my Google Home app. Is there another way?
10-22-2025 05:29 PM
Hi attommic,
Thanks for posting. I understand that you need help with your Google Nest Hub Max, which is offline, and also that you are not able to remove it from the Google Home app. Don't worry; help is here. Here are some steps that you can try on the Google Home app, and after that, you can try to remove the device again:
If, after that, you are not able to remove the device, you can try to factory reset the Google Nest Hub Max; just remember that after a factory reset, all the settings and information will be deleted from your device. That means that you would need to set up the device again on the Google Home app.
You can check the "Factory reset Google Nest or Home speakers or displays" article to know how to do it.
Please keep me posted.
Jenny
10-22-2025 05:29 PM
Hi attommic,
Jenny
