Cant make calls from Next hub max to my phone
Gspeaker
I set up my new Google Next hub (2nd Gen) with my email account and phone number but when i call it from the hub max, my phone will not ring. if i login to the Google Meet app it will say that i have a missed call. All notifications are on on my phone and i have tried resetting everything multiple times. My phone is an Iphone 14 Pro Max and is new as of 2 months ago. I have read several other threads on this and there appears to be no good answer. Has there been any resolution?
Cathal_S
Hi Gspeaker,
The calls feature works differently depending on where in the world you live. Please have a look at the Google Nest help center link below for more information and let us know if you have any further questions.
Calls:
https://support.google.com/googlenest/answer/14113295
Cathal
I live in the United States. It makes calls to everyone else just fine. It essentially thinks that I am calling myself so it won’t ring on my phone. my account on the Google hub max is my phone number. Is there a workaround for this?
Hi again,
Have you tried adding yourself as a household contact? Help center information linked below.
Household contacts:
https://support.google.com/googlenest/answer/9947117
Cathal
Gspeaker
yes, this did'nt change anything
Gspeaker
I checked with Verizon and they said that if it doesn’t go to voicemail, it should work. The Google hub rings and rings and rings and rings, and nothing comes up on my phone.
