01-13-2022 01:09 PM
I am trying to set up my Nest Hub Max and I cannot connect to the wifi. I believe it is because my wifi is password protected, but the Nest Hub never prompts me to put in a password. Any suggestions?
02-05-2022 12:10 PM
Hi Samaludl,
Glad you reached out.
Sorry to hear about your experience with connecting your Google Nest Hub Max to your network. A few things I'd like to verify regarding this:
Let's go ahead and try these steps first and let's see if this would make any changes. Make sure that when you set up your Google Nest Hub Max, it must be within range from your router preferably within 10-15 feet from the router.
If you get an error message that says "could not communicate with your [device]" when you try to forget your network, or the steps above don't work, you'll need to factory reset your device and set it up again.
Let us know how it goes.
Princess
02-08-2022 12:29 PM
Hi Samaludl,
I'd like to check if you're good to go hoping the steps I provided worked on your end.
Please let us know if you have questions regarding this and I'd be happy to answer it for you.
Princess
02-09-2022 04:14 AM
Hi! I was able to fix my problem. Thank you for following up.
03-11-2022 10:28 AM
Hey Samaludl,
Glad you were able to resolve the issue and everything is good to go. With that being the case, I am going to lock the thread at this time. If you have any questions from here, please feel free to create a new post.
