05-01-2024 06:41 PM
Hello google, I got my google nest from a friend of mine and I turned it on and it shows some green lines and a black screen. Would you able to fix it?
05-01-2024 07:00 PM
Hi @Abu1 ,
Thanks for reaching out about the green lines and black screen on your Google Nest device. It sounds like you might be experiencing a hardware issue.
In the meantime, here are a few things you can try:
If these steps don't resolve the issue, I recommend visiting the Google Nest Help Center and check the warranty status so we can look for the options available.
All the best,
Josh
