Gentle wake up doesn't work without Hue lights
wtfhits
Previously, we were using gentle wake up with Phillips Hue BT bulbs. This worked OK, but recently the reliability of the Phillips Hue bulbs have made them unusable and we are returning them. Gentle Wake up is meant to work with any lights, but it is not for us. The scenario we need is to be able to set an alarm using the built-in routine command "Ask what time the alarm should be set for" (or a similar custom command if one exists).
These are the possible setups we could use, none of which are working:
- Using a Nest Hub (2nd generation), with sunrise alarm. The reason this doesn't work is because it's not possible to set a sunrise alarm using a routine. It would have to be set manually
- Using WiFi enabled smart bulbs with either the Nest Bub or Nest Mini, with Gentle wake up enabled in the room. If I have enabled gentle wake up, nothing happens. If I ask Google to wake up my lights, it sets them to 1%, and then nothing more happens.
Does anyone have a workaround for the bug that actually works?
Work arounds I've seen:
- Set the sunrise alarm manually on the Nest Hub. No - we set the alarm for different times each day - it is ridiculous to not be able to use a routine. What is the point of them otherwise?
- Turn the light on at 1%, then have Google "wake up" the light. Doesn't help, because you can't have the light turn on half an hour before the alarm.
- Reset the devices. This happens with every device and every bulb. So no, I'm not resetting them again. Or uninstalling and reinstalling the app.
I would say it's astounding that this hasn't been fixed. But these days it's not. None of the bugs are being fixed. New features are being introduced and all existing features are just being left alone. I'm sure it's nice for the Google developers to get work on exciting new features, but you really need to spend time fixing the existing ones as well.
9 REPLIES 9
Dan_A
Hi wtfhits,
Thanks for posting. Seems like you've already exhausted all the troubleshooting steps. I would like to know more about this, please fill out this form so we can investigate further.
Keep me posted.
Dan
Muddi
Hey wtfhits,
I just wanted to check if you had the chance to fill out the form?
Muddi
wtfhits
I've filled out the form.
Princesss
Hi wtfhits,
We've received your form-- thanks for filling that out. I'll consider this post as complete and will lock the thread in 24 hours. Please keep an eye on your email as someone from our team will reach out to you to assist you further.
Princess
Muddi
Hey wtfhits,
Just an update. We send you an email about your concern and let's continue through that channel.
Muddi
wtfhits
It sort of seems weird to me that you lock threads which are clearly not resolved in any way.
You should allow other people to either offer alternative solutions, workarounds, or confirm if they've also had the same issue.
In the unlikely event that someone at Google is able to actually provide a solution, I would also like to be able to reply and mention the solution.
As it is (having seen so many closed threads without a solution), these threads just seem to be an alternative way to privately create an issue, instead of a place for public discussion of the issues.
Princesss
Hi wtfhits,
We apologize if this thread will be closed sooner than you would have liked. As Community Specialists, we occasionally do a bit of housekeeping to keep the conversations in our community fresh and relevant. This includes locking threads after a period of inactivity.
Princess
Lots of threads get closed too early. There are plenty of threads here which I would comment on to say I have the same issue.
They should not be closed unless the issues are actually fixed or a genuine solution provided. Or at the very least an admission that there is no intention to fix the problem.
Princesss
Hi wtfhits,
We appreciate your honest feedback. We expect to close the threads after creating a case as there are some info that we need that we can't disclose via a public post. No worries, I'll keep this thread open until you are assisted via email by one of our support specialist.
We thank you for your understanding.
Princess
