Audio speed so slow
Lgardner2303
When listening to my podcasts through the mini, the audio is SO slow. I usually listen to podcasts at 1.8/2 speed, my phone shows that speed but it’s definitely not coming through the speaker at that rate.
Also if I skip ahead 30 seconds (skip commercials) or go back 10 seconds, there is a serious delay and it doesn’t do it properly.
 Any fixes? I feel as though I’ve searched all the settings and can’t find anything, hopefully I’m just missing it.
6 REPLIES 6
Muddi
Hey Lgardner2303,
I understand how it feels when you're having issues listening to Podcast on your Nest Mini. To confirm, have you tried the steps above?
@RachelGomez123: I appreciate your help here.
Muddi
Muddi
Hey Lgardner2303,
How was your device? Let us know if you still need help, and we're happy to lend a hand.
Muddi
I have tried all the suggested options and it didn't work. My audio is still at a speed of 1 (even though on my phone it says 1.8).
Dan_A
Hi Lgardner2303,
That certainly hasn't been easy for you ― let’s check this out.
Could you compare the speed from other podcasts or other music platforms like YouTube if it is also affected? Also, transfer your Google Nest Mini near your router so that we can narrow things down. When you’ve tried the steps given, we should factory reset your Nest Mini to its default and original settings. Doing the set up is a must. Click this link Factory reset Google Nest or Home speakers or displays.
Keep me posted.
Dan
Muddi
Hey Lgardner2303,
I just wanted to check if you have tried to reset your device?
Muddi
Muddi
Hi Lgardner2303,
Just bumping in to make sure that you've seen our responses. I'll be locking this thread if we won't hear back from you again in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
