Google Home Max together with Nest Audio
GG4
Is it possible to play the same music on Nest Audio and Google Home Max in one room which means using the Max like a subwoofer? Do I have to group the speakers in the room or is there any other way, like pairing the speakers.
2 REPLIES 2
Cathal_S
Hi GG4,
To create a stereo speaker pair you need to use two of the same device types e.g. 2 x Nest Audios.
You can still create a speaker group and play the same music on multiple devices.
Speaker Groups:
https://support.google.com/googlenest/answer/7174267
Cathal
Cathal
Muddi
Hey GG4,
Thanks for visiting the Community. I appreciate Chathal_S for helping here.
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link. If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand.
Hope this helps!
Muddi
