01-26-2023 05:06 PM
I recently bought a Google Nest Audio and it was working fine. As of tonight though it has completely stopped functioning, and I have no idea why. Lights do not turn on under any circumstance. I've attempted to reconnect it via my Google Home app, but it could not find the device. I've plugged it into several different outlets, each one functioning with other devices, but it does not seem to power my device. I've attempted a factory reset, but I'm not able to trigger any of the buttons I'm assuming due to the lack off power.
I've attempted this fix, but the lights it mentioned should turn on never turn on:
https://support.google.com/googlenest/answer/9837834
01-30-2023 04:57 PM
Hey Chipmunk46,
We appreciate your efforts. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done. Also, could you tell us where you purchased it?
Mudd
02-04-2023 09:12 PM
Hey WillJoe123,
Thanks for sharing those steps.
@Chipmunk46: Have you had the chance to fill out the form?
Muddi
02-05-2023 09:47 PM
Hey Chipmunk46,
I haven’t heard back, so I'll be locking this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
02-01-2023 10:04 PM
General troubleshooting
Reboot your speaker or display. Disconnect the power cable from your device.
Make sure your device recognizes the hotword. Say “Hey Google” to your speaker or display.
Make sure your device recognized the question correctly.
Adjust the hotword sensitivity of your device.
Will
