02-04-2023 12:36 AM
I am having a problem with the clock on my Google Nest Hub. I have 4 of them at home and just overnight, the timezone change to California timezone instead of Central. How can I change it back? I have been looking online and tried every steps, but nothing works. Can you help?
02-08-2023 10:26 AM - edited 02-08-2023 10:42 AM
Hi Estravada,
This is not the experience that we wanted you to have, let me help you out. A few things: when did the issue start? Were there any changes made before the issue started? When you ask your Nest devices the time using voice commands, are you getting the same result? What steps have you taken so far?
When you ask for local places, weather and time information, your home address is used as the default location unless you specify another place, weather or time. Check if the address is updated by following the steps below.
Change the home address of your devices
Note: When you change the home address, it only affects the devices in the home you selected. You can edit or delete this address anytime.
Check this link for more information.
Hope this helps.
Juni
02-11-2023 11:18 AM
Hello there,
It's me again. I want to make sure you're all good — how did the steps go?
Juni
02-11-2023 11:34 AM
Hi there.
It happened overnight without anyone changing on the settings. Tried all the steps, but it remained the same.
Somehow, the clock went back to normal the next day for an hour, then it switches back to California time again after that. Since then, it will show timezone according to its preference. An hour of one timezone and another with another timezone.
Despite using the app to connect 4 devices, two will show one timezone and two showing another
02-12-2023 10:38 AM
@Juni, thanks for the help.
@Estravada, thanks for the cooperation. Let's go ahead and try the steps below in changing or editing your home and work locations:
By the way, does all 4 of your Nest devices show different, incorrect time zones or only two?
Dan
02-15-2023 12:05 PM
I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Dan
02-15-2023 12:38 PM
Hi Dan,
Two were showing different time zone and two were correct. Before I managed to try those new steps, they went back to normal. Not sure what change
02-21-2023 03:48 PM - edited 02-21-2023 03:53 PM
Hi Estravada,
Apologies for the delayed response. To isolate further, let’s factory reset one of your Nest Hub to see if the issue is device specific. Here’s how to do the reset for both Nest Hub or Nest Hub 2nd Gen and your Nest Hub Max, depending on what you choose:
Nest Hub
Nest Hub Max
If the issue is resolved after the reset, follow through with the other 3 Nest devices.
Keep me posted.
Dan
02-24-2023 06:18 PM
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
02-24-2023 06:28 PM
Hi there. I did not take those steps as they went back to normal. Do not want to mess it further, but if that happens again, I will try them out
02-25-2023 03:14 PM
Hey Estravada,
It's nice to know that your device is now showing the right timezone. We'll keep the thread open for a few more days to monitor your Nest Hub to make sure that it's fixed. Feel free to update the thread if you notice any issues with your Nest display.
Muddi
02-28-2023 06:08 PM
Hi Estravada,
How was your device? Let us know if you still need help and we're happy to further assist you.
Muddi
03-01-2023 07:03 PM
Hey Estravada,
We haven’t heard back, so I'll be locking this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
