Google Nest Hub display not allowing Home monitoring features to turn on.
Danielguerra
Google Nest Hub display not allowing Home monitoring features to turn on. Seems I am not the only one
Princesss
Hi Danielguerra,
Thanks for reaching out.
Can you confirm what type of Google Nest display are you using? If you are using a Nest Hub Max, you can follow these steps:
  1. Make sure your mobile device or tablet is connected to the same Wi-Fi or linked to the same account as your Google Nest display.
  2. Open the Google Home app .
  3. Touch and hold your device's tile.
  4. At the top right, tap Settings and then Nest Cam.
  5. Turn Home monitoring features on or off.
  6. Optional: To play audio in your live stream and recorded video, turn Home monitoring audio on or off. Note: This setting doesn’t affect any other features of the microphone. You can still use voice commands with your Nest Hub Max device if this option is turned off.
Turn the camera off from Live View
  1. Open the Google Home app .
  2. Tap Camera and then Menu 3 dot menu icon and then Turn off Camera.
Turn the camera on from Live View
  2. Tap Camera and then Turn on camera.
Let me know if this works for you.
Princess
Hey Danielguerra,
Princesss
Hi Daniel,
Jumping in to check if you still need help with this? Hope the previous post answered your question, otherwise I’ll be locking the thread.
Princess
