Having trouble with Speaker groups? Read this first
kelanfromgoogle
Community Manager (Admin)
Thank you for continuing to notify us of the reliability issues you’re facing with your Speaker groups. I escalated these issues internally and the team is actively investigating a resolution. If you’re able, all feedback is appreciated! Please keep it coming by saying “OK Google, Send Feedback." Providing details, such as mentioning that the issue is with the "speaker group," is especially helpful.  As always, we appreciate your feedback and are working hard to alleviate the issues.
Thank you for the patience,
Kelan
2 Recommended AnswerS
kelanfromgoogle
Thank you for your continued patience while our team has been working to address the issues with Speaker group functionality. I want to give you all an update and confirm that a fix was identified which will address a specific problem where some devices, when acting as the group leader, cause an issue with audio not playing on other speakers that are part of the same group. However, you may experience that the main (or leader) device will still play the media as expected.
The following devices will cause this behavior when used as the group leader:
- Chromecast with Google TV (4K)
- Chromecast with Google TV (HD)
- Google Home (Fixed as part of firmware update 3.73)
- Google Home/Nest Hub (first-generation)
- Google Home/Nest Mini (first-generation) (Fixed as part of firmware update 3.73)
- Nest Audio (Fixed as part of firmware update 3.73)
- Nest Hub (second-generation)
- Nest Hub Max
- Nest Mini (second-generation) (Fixed as part of firmware update 3.73)
- Nest Wifi Point
- Pixel Tablet
- A small percentage of third-party speakers were also affected
Note: the issue must be fixed on the device that is the leader of the group in order for the other devices in the group to start playing consistently
The fixes are specific to each device type, and are dependent on upcoming scheduled update rollouts. We will update this post as the fixes begin rolling out for each device so you can test your own speaker groups.
There may be some devices that take longer to receive the update so if you’re still encountering issues, you can try these temporary workarounds:
Cast directly: if you’re trying to play audio in multiple rooms, cast the audio directly to the individual speakers.
Restart your devices: If you’re having trouble with your speaker group and are unsure which device is the group leader, try restarting all devices that are part of the speaker group. This can often resolve the issues.
As always, we deeply appreciate the feedback and your patience. If you are still running into issues with Speaker groups, please leave a comment below with clear descriptions of the behavior you're encountering. This feedback will help the team further investigate and mitigate anything else that might be causing this feature to not work as intended.
Thanks again, we're working diligently to get everything back to how it should be.
Kelan
kelanfromgoogle
The 3.73 firmware update contained fixes for some of the issues impacting Speaker groups functionality.
These fixes are specific to the following device types:
  • Nest Audio
  • Nest Mini
  • Google Home Mini
  • Google Home
Speaker groups consisting of these devices should not experience disrupted playback. If you were experiencing issues with your Speaker groups, remove any devices from the group that do not appear in the above list and test them again. If after testing you still experience problems, please respond below with as much detail about your setup.
We appreciate your patience while the team works hard to investigate and identify fixes for the rest of impacted device types.
Thank you.
664 REPLIES 664
morf
Yes exactly this is the point. All google answer can reveal which type of company it is. The ones who can t fix a stupid software problem or the company that lies to it's customers...
So they updated the firmware to 3.73.420420 on the nest audio speakers. 5 of the 6 that received it will no longer play in a speaker! I'm down to a max speaker and 3 old audio cast devices. So out of 14 devices that worked I am down to 4 and figure 3 in a day or 2. I have spent hundreds of hours wasted along with Thousands of dollars in google products and routers thinking this was on my end, all just to listen to music!
How do I know which device was the leader?
@kelanfromgooglemight answer that, ... or not. In any case, this question has been asked several times.
I assume the chatbot @kelanfromgoogle @ is like a slot machine, just keep playing and maybe it will pay out...great odds for customer service.
My G Home app freezes when I attempt to fix speaker group. This sucks.
I have a "long" list of devices (when i access SETTINGS -> DEVICES, GROUPS & ROOMS -> Select a ROOM -> CHOOSE DEVICES)
They appear under the "ADD NEW" list!
Is there a way to remove this "old" devices?
This is one of the bugs I have reported.
So sort of retention of old devices.
Best thing is; I have and have had multiple homes and I  use similar naming conventions and I could see devices that are from a home I packed up and left a few years back. I suggested to Google this could be an issue at account level rather than home structure level.
Further example. I set up my father in law's home and then "left" it, yet I still see devices particular to that home in the same screen. I know they are his as we used a different room naming convention there.
I can only begin to imagine the issues this could potentially cause when I use voice commands with device names.
Obviously over time I have factory reset and readded the dame devices with ssne names and/or subtly different names and they are all still there.
Ridiculous.
Google's response was to ignore it and say that they passed the information to their higher level support
It makes no difference as to the leader. The issue is currently only with the nest mini's. You can start to cast from a either of the two mini's, a hub or an andriod phone. In two test groups with another speaker and one of my Nest Mini's the problem repeated with the Nest Mini playing a clicking noise (similar to an LP record skipping at the end of the album) while any other device plays the cast.
Not sure if my problem is the same but here it is:
Speaker groups aren't working anymore when I use routines.
I have a routine that does "Play Radio X on ALL"
ALL is my speaker group for all speakers around the house, and has been working fine for years and years!
If I say "Play Radio X" it should invoke this routine, and it does... but it ONLY plays music on my Google Home MAX speaker. Trying to stop the music is a pain too, as Google doesn't seem to know where the music is coming from, it feels like it's lost connection somehow.
I've had this problem before, a few months back and it eventually sorted itself out, but now it's back and I've rebooted ALL devices, and still the same problem.
I had a glimpse of what it was like for one morning where I played a different radio station, and it worked... but since then, it's gone awry again!
It's infuriating, and makes me wish I could ditch Google's services! It always used to be simple, plug and play, but now it's just getting worse and worse!
robbieq
I just have a problem with the Home Max.  When it is included in the speaker group, only the Home Max will play, none of the other speakers will play.  When I delete the Home Max from the speaker group, all other speakers will play together.  I have 2 Hub Maxes, 2 Nest Hubs (1st Gen) 2 Next Hubs (2nd Gen) and a Google Mini.  I can start casting on the speaker group without the Home Max and then add it in to the group and all will play together, but when the next time comes around to cast audio, it'll only play on the Home Max, again.  I manually have to add and remove the Home Max every time.   I decided just to leave it our of my speaker group.  Also, if it helps, to stop the music, I just say, "Hey Google, stop casting" and whatever speaker is playing, in any room, single or speaker group, will stop playing.
Lardo
This is EXACTLY what I have with my Google Home Max. It seems to steal the casting from everything else, but this has only started to happen in the past few weeks, or months.
I have now created a group without the Max, but I really hope Google sorts this out.
One thing I don't understand is that the Google Home Max Speaker is on a totally different casting firmware to any of my other speakers. Maybe this is why there are issues?
It also seems that Google has issues with Speaker groups as a whole. Not sure why it takes so long for Google Devs to figure this stuff out, they must have armies of coders !
Mishap
Yes, armies of coders but no programmers!
WhyWhy99
No I think they have 1 chatbot @kelanfromgoogle  that just repeats a scripted...we are aware...with no further updates.
We get up in the morning and turn on YouTube music and connect to all the 9 Google Max speakers in my only Group. Sometimes it works but other times it turns on only one speaker. I go to Home and turn it off go back to music and try Group again. Sometimes it works. Other times it plays another speaker in the group. Again I go to Home and turn it off and try again. The frustrating part sometimes I can't get it work and give up just playing on 1 speaker. The next morning try again and all 9 Group speakers work. Today I've been trying on and off for 4 hours trying everything I can think of.
It's not you or anything inside your control.
It's their software
My Google Nest speakers have the latest firmware of 3.73, but I am still experiencing the problem with volume not working even at 100% it sounds more like 20% when they are paired.
I had this with Amazon Music. I'd set the music audio to be normalised, which, weirdly, reduces the volume of ALL music so much I thought my Google speakers were playing up.
Wondered if you might have done the same thing, but if not, it's probably yet another issue with Google Home stuff.
After playing a somewhat successful game of Whack-A-Mole with different speaker groups the past week or two, it appears google has managed to screw it up again!!! After trying my usual bag of tricks to listen to some music nothing seems to help. In the "home app" under "devices" the speakers now have two buttons for each speaker. There is the one that has always been there with the volume percentage and now there is a second button for the same speaker but just a toggle on or off! WTF!!!!!!
This is a freaking nightmare, clearly google has absolutely no idea how to fix this! This all stems from the law suite they lost several years back and they have been attempting to create their own code but how could they? If they remotely tried to test this they would see what piece of crap they turned this in to!
The on/off button does not **bleep** thing, just more code for them to screw with!
The On/Off button in the home app was not added by Google. In my quest to fix/find alternative to this mess I have jumped down the home automation rabbit hole. Sorry for the miss information and problems this may have caused.
How exactly is this "group leader" designated and is it possible to just change it? I rarely speak to get use my speaker groups and this still sounds vague.
You definitely won't get an answer to that here because there probably isn't one!
Speaker groups decided to stop working when issuing voice commands
Example:
Hey Google, play <radio-station-name> from <app or provider> on <speaker-group-name>
This used to work fine, but now all I get is:
      "Sorry, I don't understand"
I have deleted and created a new speaker group.
I have reset all the Nest Mini devices.
I have deleted and re-created the "home"
I have reset my router and reconfigured it, all to no avail.
Is this an ongoing issue?
Should I dispose of the Nest devices and switch to Amazon, as that works fine when I use it elsewhere?
Please can you let me know of a fix or at least that your are aware of the issue and are trying to rectify it, from the threads I have seen tonight, it appears that this has been happening for a while.
Thanks
Beth
There are Echo's with audio out. I will be testing that for my 2 speaker groups. It's a shame that Google won't support or live up to their comment for what they sold all of us.
It's a shame, as when they work as you want them to, the nest and home are fantastic.
I just want to know why they have suddenly stopped working (speaker groups), when issuing voice commands. It's infuriating.
Anyway one more attempt to resolve the issue when I get time, if that doesn't work, I will look elsewhere.
Ended up trying another factory reset and reconfigured my router, everything is connected properly and now the speaker groups work.
It's annoying, this shouldn't have to be the default solution to fix the errors, but at least it's now working again.
Thank you for your message. How about the google chromecast audio? I have an Subwoofer acting as a speaker. It was working flawlessly. But i hope that also getting fixed... Or let us choose a speaker-leader. Then i think the problem is also fixed with a workaround. Thank you for your reply!
So kelan wrote .......... "Restart your devices: If you’re having trouble with your speaker group and are unsure which device is the group leader, try restarting all devices that are part of the speaker group. This can often resolve the issues."
Multiple people have asked with no reply "How Do We Know Which Is the LEADER". Someone last week reported finding the Leader using WireShark, I installed it and spent hours trying to learn it. I had already created spreadsheets with devices IP address etc, trying to see what was going on. My router shows each devices download and upload speeds. I finally noticed one of the speakers in the group was uploading at  over 900 kbps! I confirmed this was the leader in my Logbook in Home Assistant.
So was wondering how to pick the Leader of the group? I created a new group with just one speaker and started casting to it. I then proceeded to add additional speakers to the group and the original speaker is indeed the LEADER!
You may ask what difference does it make? It confirms my initial thoughts that there is a buffering issue "the stammering stuttering" when things start to go wrong. Turns out after every song plays each speaker "Buffers" for a fraction of a second then goes back to "Playing". So if the leader has less than perfect signal it Hits The Fan!
CHAZZER
Following
Several weeks ago I segregated my speakers that did not have the 3.73 update and it has been very reliable only a few times needed to play Speaker Whack- A-Mole. I started a new group with the leader 15 feet from primary router and have the 7 segregated along 5 that have 3.73 update so far so good?
CHAZZER
How do you know it's the leader?
JohnLand
My router shows upload and download speeds for each device connected to it. The leader is the only speaker uploading huge amounts of data.
Now... that's a ROUTER!!!!!
I have my ISP router (because it's a cable one, and i don't want to have 2 devices to segregate the MODEM / ROUTER combo) and it gives me absolutely NO CONTROL (the configuration is even made "remotely", through a OEM UI made by the ISP...)
Since 2017 not counting my initial ISP router, I have purchased 3 different router setups  thinking they where the problem with speaker groups.
JohnLand
Also I jumped down the home automation rabbit hole and Home Assistant Logbook confirms it by calling it "leader "
Home Assistant logbook? Where do i get that?
Home Assistant is a open source home automation that runs on your local network. The logbook is a log of all devices running on my network
Can you share more details on how you got this info?  I have Home Assistant setup and my Google homes setup using both the Google Cast and Google Home integrations.  I'm not seeing the leader information in the logbook nor am I seeing it in the device/entity attributes.  Any help would be appreciated.
