Home Max is set up at two different addresses
Patti512
I had trouble setting up a Google Max at address number 2 so I redid it using my home on my phone now when I try to call my friend Google keeps on calling my Google Max at my house what did I do wrong.... It had been working for quite a while and then it stopped so I tried to change it now I'm screwed!
Princesss
Hi Patti512,
Let's go ahead and try these steps:
  1. Open the Google Home app .
  2. At the top, make sure your home name is listed. If needed, tap the name to change the selected home.
  3. Tap Settings and then Home information and then Home address​.
  4. Tap Edit and then Enter your address and then Next.
  5. Drag the map so the pin is on your home, then tap Done.
Note: When you change the home address, it only affects the devices in the home you selected. You can edit or delete this address anytime.
Keep me posted.
Princess
Princesss
Hello Patti512,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest devices and we'd be glad to assist you further.
Princess
Princesss
Princess
