08-28-2023 01:45 PM
I got a new modem and had to change my network and password. I reset and reboot my mini to add it to the new network but it will not add. I followed the steps as per the support page but nothing works. The mini connects to the phone and they can communicate but it cannot connect to the Wi-Fi. Can you suggest something? Please note that I have already done all of the things as prescribed in the support posts regarding this issue.
09-01-2023 11:03 AM
Hi Paulko8b,
I’m sorry to hear the trouble you’re experiencing during setup. Let’s further look into it. A few questions: what’s the message you’re getting when connecting to the WiFi? Are you using a dual-band router? If yes, on which band are you trying to connect your Google Home Mini?
Alex
09-04-2023 02:21 PM
I'm having the same issue. I tried all the steps laid out in the thread below with no success:
09-05-2023 08:56 AM
Hello Agutierrez1975,
This certainly hasn’t been easy for you. I just wanted to confirm, you can’t find a “GoogleHome.XXXX” open network in your phone’s WiFi settings, is that right? Same as when using another setup device?
Kind regards,
Alex
09-05-2023 11:22 AM
Hi Alex,
Sorry for any confusion, I did find the "GoogleHome.XXXX”. I tried connecting my mini the traditional way using my android, then I tried my ipad, then I tried using the GoogleHome.XXXX that showed up as a wifi connection and still no success. I am going to try it from on a different wifi network to see if there is a block or something
09-06-2023 11:24 AM
Thanks for the update. You can try connecting your Google Home Mini to a temporary Hotspot. You need to have 2 setup devices for this.
Keep us posted!
Alex
09-07-2023 08:43 AM
I tried the hotspot method and it did not work
09-07-2023 09:41 AM
Hey Agutierrez1975,
We appreciate all your efforts. We'd like to take a deeper look into this for you. Please fill out this form with all the needed information, and then let me know once you're done.
Warmly,
Alex
09-09-2023 09:56 AM
We haven’t seen your form submission come through—were you able to access it alright? Let us know if you’re running into trouble or still need our help.
Sincerely,
Alex
