How do I stop my Nest Hub Max from changing from my photo frame when I approach it?
Sunshine2
I use 2 of these devices to rotate photos, but when I approach each morning and each evening it changes to a 2nd tab when I approach.  I see others had the same issue and were told to turn off motion activation.  I do not have that option or cannot find it.  Can anyone help?
Dan_A
@MikeClark, thanks for the help.
@Sunshine2, have you tried the suggestion above about setting "Personal Photo Curation" to "Live albums" only? It would help a lot to check out this guide about photo frame settings. Also, to check the status of your motion sense, follow the steps below:
  1. From the bottom of the display, swipe up.
  2. Tap Settings > Motion Sense > turn on/off Motion Sense.
Keep us posted.
Dam
