Hub Max 1st gen connection to Nest Cam
Pdesjardins
I have Nest door bell and outdoor wired Nest Cam. The latter regularly looses connection with my Hub Max 1st gen while I still have connection with Cam on my iPhone. Door bell rarely loose connection. Tried reboot network and disconnect Cam and Hub Max and issue keeps coming back. -Frustrating!
jenniffert
Hi Pdesjardins,
Thanks for posting in the community! I'm sorry to hear that your Nest Hub 1st Generation is losing connection with your Nest Cam Outdoor. Help's here!
To better investigate the inconvenience, I'd like to ask for the following information:
  • When did the issue start?
  • Which app are you using for the Nest Cam Outdoor and for the Nest Hub 1st Gen?
  • Have you checked if the camera shows online in the app when it gets disconnected from the Nest Hub?
  • Did you receive any error messages when the camera gets disconnected from the Nest Hub?
In the meantime, I'd suggest the following steps:
Please keep me posted.
Jenniffer
Its been ongoing for quite some time.
I use the Nest App to view the Nest Cam on mu iphone and it still shows on the phone when it gets disconnected from Hub, No error messages.
A lot of time to remedy this issue, I ask Google to show me the camera on doorbell and then to show me the Nest Cam which renews the connection, but it gets annoying after a while...
jenniffert
Hi Pdesjardins,
Thanks for following up! I appreciate the details provided.
To continue investigating this situation, I'd like to gather the following information:
  • Is your Nest device within 15 to 20 feet of your Wi-Fi router?
  • Are there other Google Nest displays set up and working in the home? If so, are they experiencing the same inconvenience?
For now, I'd suggest the following steps:
If the above steps don't work, you might consider performing a factory reset on your Nest Hub Max. Please refer to this article for guidance: Factory reset Google Nest or Home speakers or displays.
Let me know how it goes.
Jenniffer
Pdesjardins
Hi Jennifer.
Device is within 20'. I have another display in basement (Nest Hub) I dont spend that much time in basement and cant really comment on its performance. Will need to monitor...
Firmware on Hub max is correct. I restarted the router and \hub Max. No effect!
Will work on factory reset later today and get back to you...
Thanks, Pat
jenniffert
Hi Pdesjardins,
Thanks for the reply!
I'd appreciate it if you could let me know what the result was after performing a factory reset on the device. And it would be very helpful if you could move the router a bit closer to the Nest Hub and Nest Cam.
Keep me updated.
Jenniffer
