Hub Max Thread Network Key
Dt455
Hello, I am attempting to use a hub Max as the thread router for my smart things network using a 2015 smart things hub as marshal.  This should be possible per their documentation but I am getting stuck because I can't find the key for the thread network created by the hub Max.  Any ideas how I can retrieve the key?
https://support.smartthings.com/hc/en-us/articles/11219700390804-SmartThings-x-Matter-Integration-
Once connected select the Wi-Fi or Thread network if necessary
For users adding Thread devices with a SmartThings 2015 Hub, you will need to select an existing Thread border router and enter its Thread Network Key
Muddi
Hello Dt455,
Thanks for reaching out. To use the Google Nest Hub Max as a thread network, make sure that it is connected to the same network where your SmartThings device is connected. Also, please set up your SmartThings Hub first on the native app, then proceed with connecting it to the Google Home app using an Android device.
Have a look at this article and let us know if you need more help: How Google products use Thread
Muddi
