11-24-2023 05:16 PM
my google nest that is plugged in works beautifully. I had wanted to have a speaker in my bathroom, but a plug is not available. I purchased a N2 battery base, assuming that it would work underneath the counter. However, when plugged in on the base, I cant get a connection. When I take it off I can pair the speakers and it works great. When I unplug to put on base, I lose it!!! Any suggestions? am I doing something wrong?
11-24-2023 07:41 PM
That is a 3rd party base and unfortunately not supported by Nest Google. That being said, check that there isn't an on/off switch that is toggled and be sure it is fully charged. Otherwise, I would reach out to the manufacturer and see if they offer any ideas.
11-24-2023 08:10 PM
thank you
