Incorrect temperature sleep sensing
abugintheground
The temperature recorded on my nest hub sleep sensing is wildly inaccurate (37°C, should be more like 23-25 at it's hottest.. I'm only in the UK!).
- is there an internal thermometer that needs recalibrating or is faulty?
Or
- is this picked up from weather data?
Any ideas?
51 REPLIES 51
Yes, however no difference.
Fedore
Hi
I have the same issue, I'm bumping this thread so I can get a notification if there is an update.
/Robert
MikeShep
My Nest Hub 2 is the same, every night it shows 37° C. If it only happening with some hubs I would assume there is a problem with the sensor.
Mike
curiousities
I've been having the same problems as others here for a while (maybe 2-3 months plus). Both light and temperature sensors display incorrect information in the sleep quality section. Showing 40C overnight in a room that is 22C, showing Bright in a room that is fairly dark. The weather report functions are fine, it's the internal ambient light and temp sensors for sleep functions that are displaying wrong.
jherald
I’m having the same problem. The sleep sense never reads below 97F even though it is has never been warmer than 75F.
Fuchsia v. 12.20230611.67
Software v. 53.110.0.549404370
Chromecast v. 1.70.377722
MunchZkin
Any updates regarding this, it's-2 °C out here according to the weather app reported by nest hub. But shows 31° C in my sleep record.
I just bought it yesterday and made sure it is updated to the latest software. Help please
Joerg
Finally, the temperature sensor is working (again) since about one week now!
Fuchsia-Version
14.20230831.4.72
Softwareversion
54.103.7.577294944
Chromecast-Firmwareversion
3.71.387262
Juni
Joerg, thanks for the feedback. We're glad that it’s working on your end now.
We want to confirm if others are still experiencing this. If so, please check the version of your device and make sure it’s updated. Check out the helpful link below.
Check the firmware version of your speaker or display
Juni
MikeShep
The light and the temperature readings seem to be correct for me now. It would have been nice if you had kept us informed that you were aware of the problem and were working on it though.
Mike
Juni
Hi MikeShep,
Thanks for the feedback. We are glad that it’s working on your end now. Give us a shout if something comes up — you know where to find us!
Juni
abugintheground
@Juni looks like mine is working now too, great news!
Out of interest, are you able to give any info on what the fix was?
Juni
Hello  abugintheground,
Updates are being sent to devices from time to time, and they include fixes to concerns that are being reported by our users. Don’t hesitate to let us know if you need us again soon.
Juni
