Is there a way to default to Auto Frame in Duo calls? It reverts to no Auto Frame after calls.
Rdianco
Disclaimer: This thread was migrated from our previous version of the Google Nest Community. You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original poster: John Moritz
Duo on the Nest Hub Max reverts back to no auto-framing after each call.  Is there a setting that will default Duo calls to auto frame or a verbal command?  Any help is appreciated.
frances
Hi John Moritz,
Thank you for your post. Duo calls are a great feature, so I understand your concern. I would be more than happy to help answer your question.
First, I just wanted to check in. Has your issue been resolved or is this still an ongoing issue?
Thank you for your patience, I look forward to your response.
frances
Hi All,
Just checking in to see if you have any other questions or concerns. Please keep us updated, we're here to help!
frances
Hi All,
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
