It will stop and repeat the same word over & over then freeze, not respond, shut off.
Rdianco
Disclaimer: This thread was migrated from our previous version of the Google Nest Community. You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original Poster: Glow Wo
I have plugged it into another wall socket. {it was already plugged into a wall socket} it is well ventilated and I have performed the factory reset, etc. My device shuts off in the middle of playing. It gets stuck on a word, repeatedly says it, THEN it will FREEZE or Shut down. {it goes to the black screen with a white G or it’ll simply Not respond at all.  This has happened about 8 times now within the last month. I am concerned because Last year this happened and it never came back on. I was sent a new one, after a while of waiting, so I’d love to get this resolved without the long wait. Thank you! 🙏🏾💜🙏🏾
Rdianco
Hi Glow Wo,
Thank you for reaching out. Oh no! I am sorry to hear that you have been experiencing issues with your device. I understand how frustrating this issue is, and I would be more than happy to help. First, I have some questions to get a better understanding of this situation.
  • Which Google device is this post in regard to? (model name, generation number)
  • Have you been sent a new device from Google Support?
  • Is this your new device that is having issues?
  • Can you try to reboot and Factory Data Reset your device? Is there any improvement?
    • A factory reset will reset your Google Nest or Home speaker or display to its default factory settings. Note: This action will clear your data from the device and can't be undone.
Thanks for your patience!
- From Frances (Community Specialist)
