07-08-2023 11:23 AM - edited 07-08-2023 11:25 AM
Trying to add Matter devices that have thread, Eve plug & Aqara Door windows sensor P2 using Nest Hub Gen 2 firmware 11.20230306.3.112014 but get stuck on Getting Network Connectivity? Then sometimes get Cannot connect to Thread network? I've rebooted lots of times.
07-14-2023 04:20 PM
Hi Pw24,
Thanks for reaching out.
You can add non-Google Nest Matter-enabled devices to the Google Home app so you can control Google Nest and non-Google Nest devices with one app. The Google Home app will guide you through the steps.
If you want to connect non-Matter devices to the Home app, you can find the instructions in Set up smart devices in the Google Home app.
Make sure that all of these are checked:
Hope this helps.
Princess
07-16-2023 01:12 AM
Those steps you posted for MATTER is what I've don't & get the error I have posted. The nest 2nd gen is on 11.20230306.3.112014 not sure if it's that device or Google Home that's gotten corrupted. Any help I can't add any device, I can't even pair a device from Alexa to Google home?
07-20-2023 09:00 PM
Hi Pw24,
Have you already tried performing a complete reset on your Google Nest speaker? Let's try that first and see if this would make any changes on its behavior.
Keep me posted.
Princess
07-20-2023 11:45 PM
Hi yes I have reset before, but I have just reset the nest hub 2nd gen again just now, but get the same message when I try to add a Thread MATTER device.
Can't connect to thread network NEST-PAN-02F*
Check that your device can work with this network type and try again.
07-21-2023 05:44 PM
We appreciate all your efforts. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Princess
07-22-2023 12:30 AM
Form filled in.
07-22-2023 04:35 AM
Hi Pw24,
We got your form — thanks for filling it out. Our team will reach out to you via email anytime soon. Please continue the conversation there as this thread will be locked after 24 hours.
Alex
