03-05-2022 10:48 AM
The mic option does not show up on my home hub or home hub max when monitoring my indoor nest cam iq. The only time the mic option shows on the hub is when I look at the camera feed on my nest doorbell.
I know that my mic settings are working for my indoor nest cam iq because I can use the mic setting on my phone apps (nest or Google home).
10-09-2022 08:49 PM
Same here. Doorbell works fine from next hub max but best cameras only show mic on the phone. Makes no sense - google!!!
10-10-2022 03:05 PM
I know how it feels when something isn’t working the way it should, let’s get this resolved. I need to know a couple of things — was this feature working before? If so, we’re there any recent changes made before it started?
Let’s try to reboot your Google Nest displays and see if this will make a difference.
Juni
10-10-2022 03:20 PM
I did reboot and nothing. Seems like an ongoing issue for more than a year from what I'm gathering reading threads here (mostly closed threads which is boggling). If it is helpful I have second Gen indoor wired nest cams and the latest doorbell model. I think everyone expects the hub to work just like the phone app in terms of controlling the cameras - and it makes it extra confusing that the doorbell allows the hub to speak through it but no other nest cam is allowed. If this is to sell more doorbells, you are shooting yourselves in the foot. If it is a bug, why hasn't it been resolved yet after 14 months... If it is a technical (hardware/software) limitation between the nest hub max and the cameras which prevents audio streaming - I would suggest you document it well and add a solution to your next hardware iteration.
Just don't keep us in the dark here
10-11-2022 09:25 AM
We appreciate people who are keen on sharing their thoughts with us. We're always looking for ways to improve and we'll take this as feedback. You can use this link to submit a feedback.
Let us know if you need more help, otherwise I'll be locking this thread after 24 hours.
Juni
10-11-2022 10:14 AM
In the page you linked I don't see a way to send feedback from the nest hub max where it would set the device info and where the issue exists... Seems like a recurring theme (sorry, had to say it - whoever is working on the assistant app and the OS for the hub should make it more Android like and fix all these gaps)
10-12-2022 08:56 AM
Hi Glen_dm,
Thank you for the information. You can use the feedback on the Google Home app so you can add the device information and other details that you would like to include.
Check the instructions below.
If you need further help let us know, otherwise I'll be locking this thread after 24 hours.
Juni
